Vinsk1969
Jan 21, 2018Aspirant
cm1000 and xfinity issues or just Docsis 3.1 issue?
Hello all. I upgraded to the Gigabit plan with Xfinity. I use my own Modem (Arris Surfboard 3.0). After realizing I needed a Docsis 3.1 I bought the Motorola MB8600 or whatever but it was 3.1. Comcast...
MattN
Apr 02, 2018Tutor
I am having the same set of issues with Comcast in Seattle area. Anyone know what I can do to debug why the CM1000 is so spotty? Every few days I lose all connectivity and have to reboot the modem. Downloaded latest patches. With previous modem the thing would work for months no issues. My wife is saying I paid out the nose for CM1000 and the thing is much worse than the 30$ Motorola we used in the past. Can't really argue with her.
To debug I wrote a program to periodically connect ever 15 seconds to a remote site and verify connectivity. Sure enough about every 1-2 days I lose all connectivity and it does not recover. Have to cold boot modem. The logging on the modem looks pretty shoddy, how can I debug this thing?
MattN
Apr 02, 2018Tutor
Please reply with some specific things I can do to debug the CM1000. The logs are pretty weak.
- MaeredythApr 02, 2018Aspirant
Mine is only dropping about once every week or two, but I still think that's too often. Otherwise it's fast and I like it. Now that I figured out how to to disable the house alarm from waking me up in the middle of the night when it drops signal I am slightly less annoyed. It is stil a pain to discover as I am trying to leave for work I have to stop and go upstairs and make time to reboot it before I can set the alarm and leave for work, but still better than being awaked at 3 am by the alarm signaling it lost connectivity.
Personally, I think it's related to Comcast and all of the changes they have been making to the streaming portal since they are being sued by the people that bought Tivo for patent infringment. My modem worked fine and I had no trouble until after Thanksgiving when comcast disabled features in their streaming portal causing customers like me to call them four times a week about features they broke by accident in the process of hastily trying to comply with the court order to remove specific features. As they then tried to do damage control, and restore the ones they broke by accident, everytime their programmers made a change, they had to push those updates to each user and I think while thye were doing all that my problem was way worse. It seems to have gotten significantly better for me in the past month now that they have restored most o fthe collateral damage
- DarrenMApr 03, 2018Sr. NETGEAR Moderator
Are you able to post the power levels of your connection?
DarrenM
- MaeredythApr 03, 2018Aspirant
Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency <tabindex=-1>Startup Procedure
Procedure Status Comment Acquire Downstream Channel 609000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Configuration File OK ------------ Security Enable BPI+ <tabindex=-1>Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 21 609000000 Hz 5.9 dBmV 40.1 dB 0 0 2 Locked QAM256 1 489000000 Hz 7.5 dBmV 41.1 dB 0 0 3 Locked QAM256 2 495000000 Hz 7.4 dBmV 41.0 dB 0 0 4 Locked QAM256 3 501000000 Hz 7.3 dBmV 40.9 dB 0 0 5 Locked QAM256 4 507000000 Hz 7.5 dBmV 37.8 dB 0 0 6 Locked QAM256 5 513000000 Hz 7.3 dBmV 41.0 dB 0 0 7 Locked QAM256 6 519000000 Hz 7.3 dBmV 40.9 dB 0 0 8 Locked QAM256 7 525000000 Hz 7.3 dBmV 40.8 dB 0 0 9 Locked QAM256 8 531000000 Hz 7.2 dBmV 40.8 dB 0 0 10 Locked QAM256 9 537000000 Hz 7.2 dBmV 40.7 dB 0 0 11 Locked QAM256 10 543000000 Hz 7.1 dBmV 40.6 dB 0 0 12 Locked QAM256 11 549000000 Hz 6.9 dBmV 40.4 dB 0 0 13 Locked QAM256 12 555000000 Hz 7.1 dBmV 40.6 dB 0 0 14 Locked QAM256 13 561000000 Hz 7.0 dBmV 40.2 dB 0 0 15 Locked QAM256 14 567000000 Hz 6.8 dBmV 40.3 dB 0 0 16 Locked QAM256 15 573000000 Hz 6.9 dBmV 40.3 dB 0 0 17 Locked QAM256 16 579000000 Hz 6.5 dBmV 40.8 dB 0 0 18 Locked QAM256 17 585000000 Hz 6.2 dBmV 40.8 dB 0 0 19 Locked QAM256 18 591000000 Hz 6.0 dBmV 40.3 dB 0 0 20 Locked QAM256 19 597000000 Hz 5.9 dBmV 40.3 dB 0 0 21 Locked QAM256 20 603000000 Hz 5.9 dBmV 40.3 dB 0 0 22 Locked QAM256 22 615000000 Hz 5.6 dBmV 39.9 dB 0 0 23 Locked QAM256 23 621000000 Hz 5.5 dBmV 39.9 dB 0 0 24 Locked QAM256 24 627000000 Hz 5.1 dBmV 39.4 dB 0 0 <tabindex=-1>Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 36100000 Hz 43.3 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 29600000 Hz 43.5 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 23000000 Hz 43.5 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 16500000 Hz 43.5 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV Current System Time: Tue Apr 03 20:06:58 2018
