Vinsk1969
Jan 21, 2018Aspirant
cm1000 and xfinity issues or just Docsis 3.1 issue?
Hello all. I upgraded to the Gigabit plan with Xfinity. I use my own Modem (Arris Surfboard 3.0). After realizing I needed a Docsis 3.1 I bought the Motorola MB8600 or whatever but it was 3.1. Comcast...
DarrenM
Apr 03, 2018Sr. NETGEAR Moderator
Are you able to post the power levels of your connection?
DarrenM
Maeredyth
Apr 03, 2018Aspirant
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 609000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Configuration File | OK | ------------ |
| Security | Enable | BPI+ |
<tabindex=-1>Downstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 21 | 609000000 Hz | 5.9 dBmV | 40.1 dB | 0 | 0 |
| 2 | Locked | QAM256 | 1 | 489000000 Hz | 7.5 dBmV | 41.1 dB | 0 | 0 |
| 3 | Locked | QAM256 | 2 | 495000000 Hz | 7.4 dBmV | 41.0 dB | 0 | 0 |
| 4 | Locked | QAM256 | 3 | 501000000 Hz | 7.3 dBmV | 40.9 dB | 0 | 0 |
| 5 | Locked | QAM256 | 4 | 507000000 Hz | 7.5 dBmV | 37.8 dB | 0 | 0 |
| 6 | Locked | QAM256 | 5 | 513000000 Hz | 7.3 dBmV | 41.0 dB | 0 | 0 |
| 7 | Locked | QAM256 | 6 | 519000000 Hz | 7.3 dBmV | 40.9 dB | 0 | 0 |
| 8 | Locked | QAM256 | 7 | 525000000 Hz | 7.3 dBmV | 40.8 dB | 0 | 0 |
| 9 | Locked | QAM256 | 8 | 531000000 Hz | 7.2 dBmV | 40.8 dB | 0 | 0 |
| 10 | Locked | QAM256 | 9 | 537000000 Hz | 7.2 dBmV | 40.7 dB | 0 | 0 |
| 11 | Locked | QAM256 | 10 | 543000000 Hz | 7.1 dBmV | 40.6 dB | 0 | 0 |
| 12 | Locked | QAM256 | 11 | 549000000 Hz | 6.9 dBmV | 40.4 dB | 0 | 0 |
| 13 | Locked | QAM256 | 12 | 555000000 Hz | 7.1 dBmV | 40.6 dB | 0 | 0 |
| 14 | Locked | QAM256 | 13 | 561000000 Hz | 7.0 dBmV | 40.2 dB | 0 | 0 |
| 15 | Locked | QAM256 | 14 | 567000000 Hz | 6.8 dBmV | 40.3 dB | 0 | 0 |
| 16 | Locked | QAM256 | 15 | 573000000 Hz | 6.9 dBmV | 40.3 dB | 0 | 0 |
| 17 | Locked | QAM256 | 16 | 579000000 Hz | 6.5 dBmV | 40.8 dB | 0 | 0 |
| 18 | Locked | QAM256 | 17 | 585000000 Hz | 6.2 dBmV | 40.8 dB | 0 | 0 |
| 19 | Locked | QAM256 | 18 | 591000000 Hz | 6.0 dBmV | 40.3 dB | 0 | 0 |
| 20 | Locked | QAM256 | 19 | 597000000 Hz | 5.9 dBmV | 40.3 dB | 0 | 0 |
| 21 | Locked | QAM256 | 20 | 603000000 Hz | 5.9 dBmV | 40.3 dB | 0 | 0 |
| 22 | Locked | QAM256 | 22 | 615000000 Hz | 5.6 dBmV | 39.9 dB | 0 | 0 |
| 23 | Locked | QAM256 | 23 | 621000000 Hz | 5.5 dBmV | 39.9 dB | 0 | 0 |
| 24 | Locked | QAM256 | 24 | 627000000 Hz | 5.1 dBmV | 39.4 dB | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 36100000 Hz | 43.3 dBmV |
| 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 29600000 Hz | 43.5 dBmV |
| 3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 23000000 Hz | 43.5 dBmV |
| 4 | Locked | ATDMA | 4 | 5120 Ksym/sec | 16500000 Hz | 43.5 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
Current System Time: Tue Apr 03 20:06:58 2018
