SuperNASman
Jan 26, 2017Aspirant
CM1000 DOES NOT work with Suddenlink
Well, the word is in. CM1000 Modem (FW 2.01.14) DOES NOT work with Suddenlink. Suddenlink came out and couldn't get it to provision. I'm just upset that I had to be the tester. Phone tech sup...
Coaie
Mar 31, 2017Aspirant
Has anyone found the issue for this? And why suddenlink keeps saying the modem is compatible and cant get it to connect?
WoodchuckTX
Jun 14, 2017Aspirant
I very much hope Suddenlink will figure out how to support this modem. The Arris router they have rented me with provides horrible performance for video conferences, etc because of the Puma 6 chipset latency. If we can't get this working I'd like to try a 24 channel modem, but I'm not sure if they'll activate it.
- TechloreJul 12, 2017Apprentice
According to the CM1000 on Amazon it is compatible with Cox and Comcast. I would check there and see if it ever get's added, I'm sure NETGEAR would be all over adding Suddenlink, among others to that list. Pretty sure only Comcast was listed originally.
If you want to use it make sure that you contact your ISP first.
- vkdeltaJul 12, 2017NETGEAR Employee Retired
We have tried to contact suddenlink number of times. they did not respond to our questions.
I think arris SB8200 is seeing same fate as well.
you can request suddenlink or escalate to their management.
