RGLawson
Feb 22, 2021Aspirant
CM1000 Event Log Error Messages
Where can I find information about the error messages in my event log? I've been having intermittent internet problems over the past week, so I checked the event log. One entry for today is: DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=38:94:ed:41:81:58;CMTS-MAC=00:ca:e5:3c:ac:7b;CM-QOS=1.1;CM-VER=3.1;
I also had error messages last week: Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=38:94:ed:41:81:58;CMTS-MAC=00:ca:e5:3c:ac:7b;CM-QOS=1.1;CM-VER=3.1;
Is there some documentation that would indicate whether these are serious errors, and whether there is anything I can do about them?
post the full event logs and the cable connections page. Those in conjunction together lets us check your line.
(a screen snip is easier to read)
- RGLawsonAspirant
You missed channel 17-24. So not sure about those channels.
Your upstream power is really low. It should be >37 and you're lower than that.
Your logs also indicate a line issue.
I'd check your line for amplifiers, signal attenuators, or splitters. Check the line for damage, kinks, old/bad/damaged/loose connections
