BennyBenX
Aug 03, 2020Aspirant
CM1000 How to stop daily reboot
Hello I need help troubleshooting why my modem restarts itself every day at a specific time. I'm not sure if it's because of a DHCP lease time or something else. Here are some log messages on my modem.
I've already tried factory resetting the modem and the problem still occurs.
Thanks.
| Cable Information |
| 2020-08-03, 03:24:22 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:a5:8f:28;CMTS-MAC=00:01:5c:ac:0c:49;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:a5:8f:28;CMTS-MAC=00:01:5c:ac:0c:49;CM-QOS=1.1;CM-VER=3.1; |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=08:36:c9:a5:8f:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; |
| 2020-08-03, 03:22:09 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:a5:8f:28;CMTS-MAC=00:01:5c:ac:0c:49;CM-QOS=1.1;CM-VER=3.1; |
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 441000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv6 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 1 | 441000000 Hz | 0.8 dBmV | 40.9 dB | 1274854132 | 0 | 0 |
| 2 | Locked | QAM256 | 2 | 453000000 Hz | 0.7 dBmV | 40.8 dB | 1273625124 | 0 | 0 |
| 3 | Locked | QAM256 | 3 | 459000000 Hz | 1.0 dBmV | 40.9 dB | 1273615915 | 0 | 0 |
| 4 | Locked | QAM256 | 4 | 465000000 Hz | 1.9 dBmV | 41.4 dB | 1273631875 | 0 | 0 |
| 5 | Locked | QAM256 | 5 | 471000000 Hz | 2.4 dBmV | 41.4 dB | 1273635629 | 0 | 0 |
| 6 | Locked | QAM256 | 6 | 477000000 Hz | 3.2 dBmV | 41.7 dB | 1273640130 | 0 | 0 |
| 7 | Locked | QAM256 | 7 | 483000000 Hz | 3.3 dBmV | 41.7 dB | 1273643389 | 0 | 0 |
| 8 | Locked | QAM256 | 8 | 489000000 Hz | 3.8 dBmV | 42.1 dB | 1273647312 | 0 | 0 |
| 9 | Locked | QAM256 | 9 | 495000000 Hz | 4.0 dBmV | 42.2 dB | 1273652891 | 0 | 0 |
| 10 | Locked | QAM256 | 10 | 501000000 Hz | 4.3 dBmV | 42.1 dB | 1273656043 | 0 | 0 |
| 11 | Locked | QAM256 | 11 | 507000000 Hz | 4.5 dBmV | 42.3 dB | 1273660222 | 0 | 0 |
| 12 | Locked | QAM256 | 12 | 513000000 Hz | 4.6 dBmV | 42.4 dB | 1273663449 | 0 | 0 |
| 13 | Locked | QAM256 | 13 | 519000000 Hz | 4.3 dBmV | 42.1 dB | 1273667499 | 0 | 0 |
| 14 | Locked | QAM256 | 14 | 525000000 Hz | 4.0 dBmV | 41.7 dB | 1273671538 | 0 | 0 |
| 15 | Locked | QAM256 | 15 | 531000000 Hz | 3.4 dBmV | 41.4 dB | 1273675272 | 0 | 0 |
| 16 | Locked | QAM256 | 16 | 537000000 Hz | 3.3 dBmV | 41.4 dB | 1273679172 | 0 | 0 |
| 17 | Locked | QAM256 | 17 | 543000000 Hz | 3.8 dBmV | 41.6 dB | 1273690449 | 0 | 0 |
| 18 | Locked | QAM256 | 18 | 555000000 Hz | 4.2 dBmV | 41.7 dB | 1273694924 | 0 | 0 |
| 19 | Locked | QAM256 | 19 | 561000000 Hz | 4.1 dBmV | 41.5 dB | 1273697669 | 0 | 0 |
| 20 | Locked | QAM256 | 20 | 567000000 Hz | 3.7 dBmV | 41.4 dB | 1273702046 | 0 | 0 |
| 21 | Locked | QAM256 | 21 | 573000000 Hz | 3.8 dBmV | 41.5 dB | 1273705832 | 0 | 0 |
| 22 | Locked | QAM256 | 22 | 579000000 Hz | 3.9 dBmV | 41.4 dB | 1273709807 | 0 | 0 |
| 23 | Locked | QAM256 | 23 | 585000000 Hz | 3.7 dBmV | 41.2 dB | 1273712729 | 0 | 0 |
| 24 | Locked | QAM256 | 24 | 591000000 Hz | 3.8 dBmV | 41.2 dB | 1273716821 | 0 | 0 |
| 25 | Locked | QAM256 | 25 | 597000000 Hz | 3.7 dBmV | 41.1 dB | 1273721241 | 0 | 0 |
| 26 | Locked | QAM256 | 26 | 603000000 Hz | 3.3 dBmV | 41.0 dB | 1273719949 | 0 | 0 |
| 27 | Locked | QAM256 | 27 | 609000000 Hz | 3.5 dBmV | 41.0 dB | 1273722250 | 0 | 0 |
| 28 | Locked | QAM256 | 28 | 615000000 Hz | 3.4 dBmV | 40.8 dB | 1273723423 | 0 | 0 |
| 29 | Locked | QAM256 | 30 | 621000000 Hz | 3.5 dBmV | 40.6 dB | 1273722148 | 0 | 0 |
| 30 | Locked | QAM256 | 31 | 627000000 Hz | 3.3 dBmV | 40.6 dB | 1273703685 | 0 | 0 |
| 31 | Locked | QAM256 | 32 | 633000000 Hz | 3.9 dBmV | 41.0 dB | 1273703851 | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| 1 | Locked | ATDMA | 1 | 36500000 Hz | 53.0 dBmV |
| 2 | Locked | ATDMA | 2 | 30100000 Hz | 53.5 dBmV |
| 3 | Locked | ATDMA | 3 | 23700000 Hz | 53.3 dBmV |
| 4 | Locked | ATDMA | 4 | 17300000 Hz | 53.0 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1, 2, 3 | 29 | 693000000 Hz | 5.2 dBmV | 38.8 dB | 1108 ~ 2987 | 213681973 | 199136110 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | -0.7 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
| 2 | Not Locked | Unknown | 0 | 0 Hz | 0 dBmV |
- Tbones3141AspirantSame issue just started. I have the same firmware. What gives? Anyone got ideas?
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Any progress on this?
BennyBenX wrote:Hello I need help troubleshooting why my modem restarts itself every day at a specific time. I'm not sure if it's because of a DHCP lease time or something else. Here are some log messages on my modem.
I've already tried factory resetting the modem and the problem still occurs.Thanks.
- vkdeltaNETGEAR Employee Retired
extremely high Upstream power. It is blasting at 53dBmV right now which is very high.
do you have any splitters?
If not, you should request ISP to reduce the US attenuation.
