LooseNut's avatar
LooseNut
CM1000 Installation/Setup Question
Hello Group,
I am planning to upgrade my cable (Xfinity) modem, and eventually bump up to the gigabit plan.
I have a question that I hope someone can answer.
Will the netgear cm1000 (DOCSIS 3.1) ultra-high speed cable modem work okay with a slower (150mbp) plan, until i get switched over to the gigabit plan?
Thanks in advance
LEW
  • Yes, the cm1000 will have no problems with slower service. Itll run 150mbps fine.
  • plemans's avatar
