Ghery's avatar
Ghery
CM1000 is not talking to routers over Ethernet
I bought a CM1000 from Best Buy this afternoon.  This is to replace a Motorola cable modem I've had for a number of years with something faster.  After a bunch of fooling around with Comcast the CM1000 is talking to their network.  It is not, however, talking to my network.  The only exception is if I connect a laptop directly to the CM1000.  The Ethernet light is red unless only a single computer is connected.  Not acceptable.  Any ideas before I take this thing back to Best Buy?  Netgear's support stinks as it is only available during certain hours and they want "Proof of Purchase", which downloads from Comcast in a format that this website will not accept.
  • > [...] After a bunch of fooling around with Comcast [...]
       Not much meat on that bone.
    > [...] It is not, however, talking to my network. [...]
       And how would it do that?  Through some (unspecified, secret(?))
    router or other?
    > [...] The Ethernet light is red unless only a single computer is
    > connected. [...]
       Any "a single computer", or one specific "a single computer"?
          https://community.netgear.com/t5/x/x/m-p/1574972
    • Ghery's avatar
      Ghery
      Snarky replies aren't very helpful...
      "talking to my network" means just what you suppose it means - through the Ethernet connection.  Connect it to either router or the switch and you get a red light.  Connect the cable modem directly to the laptop I'm using and you get a green light.  Red light = no joy in communicating with anything over Ethernet.
      • > Snarky replies aren't very helpful...
           Not answering specific questions is what's really unhelpful in these
        situations.  Along with information-free problem descriptions.
        > [...] Connect it to either router or the switch and you get a red
        > light.
           Still wondering what that mysterious "router" might be,
           And what is your "the switch"?  Connecting a modem directly to a
        network switch would very likely cause trouble with multiple client
        devices.  Why involve it, whatever it is?
        > [...] Connect the cable modem directly to the laptop I'm using and you
        > get a green light. [...]
           Yeah, I got that the first time.  Hence the other (still unanswered)
        questions.
