Brian88195's avatar
Brian88195
Cm1000 lan connector not working
Cm1000 modem where the power, down/upstream and internet light are all solid green. The lan light is off. Rebooted and reset the modem, changed cables and connected a laptop directly to the modem.
  • FURRYe38's avatar
    Does wiggling the lan cable while plugged in do anything. Thought maybe the connector on the modem could have come loose.
    Directly connected with a wired PC?
    If nothing seens to bring the connection LED alive, the modem maybe bad.
    • Brian88195's avatar
      Brian88195
      Tried wiggling the cable and that didn’t work. Connected to a laptop and no difference. Called Netgear and did all of the tips they had. They came to the conclusion that my 14 month old router needs to be replaced. So I replaced it with an ARRIS one.
