Bostonfan49's avatar
Bostonfan49
cm1000 modem 3.1 Voice bundled question
I have Comcast with bundled voice but using Comcast Voice/data modem. Can I still use the CM1000 for my internet? Thanks, Bill
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    yes if comcast will give you a separate MTA modem for the phone.
    DarrenM
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    they may still charge you rental fees. Please check with Comcast.
    if they still charge you fees, you are better off renting..
