CNP
Feb 08, 2018Aspirant
cm1000 modem 3.1
What are the difference between CM1000-1AZNAS and CM1000-100NAS. Need convincing technical answers
antinode
Feb 08, 2018Guru
Not sure how convincing or technical, but:
https://community.netgear.com/t5/x/x/m-p/1500732
It's more a marketing question than a technical question.
CNP
Feb 09, 2018Aspirant
Thank you,
Are these the new 2017 "DOCSIS 3.1 Full Duplex" compatible device or just DOCSIS 3.1 ?
- antinodeFeb 09, 2018Guru
> just DOCSIS 3.1 ?
I don't know. And if they're not, then I couldn't tell you whetherit's a hardware or firmware question.
I also couldn't tell you whether your ISP uses "full duplex".- vkdeltaFeb 12, 2018NETGEAR Employee Retired
no product difference but packaging may be bit different.
same HW/SW.
