CNP
Feb 08, 2018Aspirant
cm1000 modem 3.1
What are the difference between CM1000-1AZNAS and CM1000-100NAS. Need convincing technical answers
CNP
Feb 09, 2018Aspirant
Thank you,
Are these the new 2017 "DOCSIS 3.1 Full Duplex" compatible device or just DOCSIS 3.1 ?
antinode
Feb 09, 2018Guru
> just DOCSIS 3.1 ?
I don't know. And if they're not, then I couldn't tell you whether
it's a hardware or firmware question.
I also couldn't tell you whether your ISP uses "full duplex".
- vkdeltaFeb 12, 2018NETGEAR Employee Retired
no product difference but packaging may be bit different.
same HW/SW.
