Smiley3303's avatar
Mar 23, 2018
CM1000 Modem Internet Connection drops Midco
Same problem as many. Disconnects hard and needs reboot to get internet back. Midco has checked connections and cables I can get close to a Gbps when it works but drops connection often.
https://i.imgur.com/pvwsqqS.png
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
<tabindex=-1>Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel549000000 HzLocked
Connectivity StateIn progressParams Transfer Complete
Boot StateIn progressUnknown
SecurityIn progressBPI
IP Provisioning ModeHonor MDDIPv4 only
<tabindex=-1>Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM25678549000000 Hz-7.9 dBmV41.1 dB00
2LockedQAM25662453000000 Hz-7.0 dBmV41.5 dB00
3LockedQAM25663459000000 Hz-7.2 dBmV41.5 dB00
4LockedQAM25664465000000 Hz-6.9 dBmV41.7 dB00
5LockedQAM25665471000000 Hz-6.9 dBmV41.7 dB00
6LockedQAM25666477000000 Hz-7.1 dBmV41.5 dB00
7LockedQAM25667483000000 Hz-7.1 dBmV41.6 dB00
8LockedQAM25668489000000 Hz-7.2 dBmV41.3 dB00
9LockedQAM25669495000000 Hz-7.4 dBmV40.9 dB00
10LockedQAM25671507000000 Hz-7.2 dBmV41.3 dB00
11LockedQAM25672513000000 Hz-7.2 dBmV41.5 dB00
12LockedQAM25673519000000 Hz-7.4 dBmV41.3 dB00
13LockedQAM25674525000000 Hz-7.8 dBmV41.3 dB00
14LockedQAM25675531000000 Hz-7.9 dBmV41.1 dB00
15LockedQAM25676537000000 Hz-8.1 dBmV41.1 dB00
16LockedQAM25677543000000 Hz-7.6 dBmV41.3 dB00
17Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
18Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
19Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
20Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
21Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
22Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
23Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
24Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
25Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
26Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
27Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
28Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
29Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
30Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
31Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB00
<tabindex=-1>Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec33000000 Hz50.0 dBmV
2LockedATDMA25120 Ksym/sec26000000 Hz48.8 dBmV
3Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
4Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
5Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
6Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
7Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
8Not LockedUnknown00 Ksym/sec0 Hz0.0 dBmV
<tabindex=-1>Downstream OFDM Channels
ChannelChannel IDIndicatorSubcarrier Zero FrequencyActive Subcarrier Number RangeTotal CodewordsUncorrectable Codewords
1159Non-Primary521600000 Hz628 ~ 346700
20Non-Primary0 Hz0 ~ 409500
<tabindex=-1>Upstream OFDMA Channels
ChannelUpstreamIsMutedRanging StatusSubcarrier Zero FrequencyActive Subcarrier Number RangeSymbols Per FrameTx Power
1 Other0 Hz0 ~ 000 dBmV
2 Other0 Hz0 ~ 000 dBmV
Current System Time: Sat Mar 24 00:53:47 2018
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Smiley3303
    This modem was only certified to work with Comcast does MIDco say this modem will work properly with there system?
    DarrenM
