ossy43
Jul 18, 2018Aspirant
CM1000 not connecting at gigabit speeds
I'm having problems with my gigabit connection, I'm just able to get 350 Mbps instead of 900+
I already reset the modem, did factory reset.
Nothing works.
- vkdeltaNETGEAR Employee Retired
which ISP?
have you confirmed that ISP has pushed correct bootfile/config file?
- ossy43AspirantRCN in NYC.
Yep according to them I should be getting gigabit speeds. But the max I get is 500mbps.
Connecting direct the modem to my desktop computer using an ASUS XG-C100C 10G Network Adapter PCI-E x4 Card.- vkdeltaNETGEAR Employee Retired
What FW are you on?
this looks could probably be configfile/bootfile or a capacity issue. Have you tried any other RCN supplied modem and recieved close to 800-900 Mbps ?
