unrulycow
Jan 09, 2017Aspirant
CM1000 on TIme Warner / Charter
I am on Time Warner Cable (soon to be Charter) in Maine. I am looking into getting a CM1000, but it only mentions Comcast on Netgear's page. Does anyone know if it will be supported once Charter get...
vkdelta
Feb 05, 2017NETGEAR Employee Retired
CM1000 is not supported by ISP you have mentioned.
thehinac
Feb 13, 2017Guide
Ummm it's Doc 3.0 compantable... Soooo... Why exactly does it not work with Time Warner when other Doc 3.0 modems off the shelf do?
- vkdeltaFeb 13, 2017NETGEAR Employee Retired
D3.1 is backward compatible with D3.0 and NOT D2.0.
If your ISP is running either D2.0 modes on any path, it is not compatible. Have you see any D3.1 modem certified by them? Have you seen any D3.1 trials? Probably not.
- thehinacFeb 14, 2017Guide
Did anybody say anything at all about D2.0? No. They didn't. Just 3.0. They still have hooked on phonics downloadable somewhere. :)
- vkdeltaFeb 15, 2017NETGEAR Employee Retired
yes, D2.0 for above mentioned ISPs. Dont assume they have full D3.0 everywhere in both forward and return path nationwide.
D3.1 is not compatible with D2.0. It needs full D3.0 atleast.
