Madlad90046
Sep 21, 2020Aspirant
CM1000 Spectrum ISP dropping every 5-30 minutes
Hooked up new Modem using the same connection I used for the spectrum modem no changes and everything worked fine for years except with 2 people working from home I wanted the multi channel upload. The modem drops every 5-15 minutes is down for 10 sec up to a minute. I'm running RG6. I really appriciate the help.
| Hardware Version | 2.02 |
| Firmware Version | V3.01.06 |
| CM certificate | Installed |
<tabindex=-1>Startup Procedure</tabindex=-1>
| Procedure | Status | Comment |
| Acquire Downstream Channel | 705000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enable | BPI+ |
| IP Provisioning Mode | Honor MDD | IPv4 only |
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR / MER | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | QAM256 | 31 | 705000000 Hz | 1.1 dBmV | 40.2 dB | 53840152 | 117 | 144 |
| 2 | Locked | QAM256 | 1 | 693000000 Hz | 1.6 dBmV | 40.4 dB | 52725699 | 0 | 0 |
| 3 | Locked | QAM256 | 2 | 525000000 Hz | 6.1 dBmV | 42.3 dB | 52729889 | 0 | 0 |
| 4 | Locked | QAM256 | 3 | 531000000 Hz | 5.7 dBmV | 42.2 dB | 52733540 | 0 | 0 |
| 5 | Locked | QAM256 | 4 | 537000000 Hz | 5.4 dBmV | 42.0 dB | 52737244 | 0 | 0 |
| 6 | Locked | QAM256 | 5 | 543000000 Hz | 5.4 dBmV | 41.9 dB | 52741150 | 0 | 0 |
| 7 | Locked | QAM256 | 6 | 549000000 Hz | 4.8 dBmV | 42.1 dB | 52744682 | 0 | 0 |
| 8 | Locked | QAM256 | 7 | 555000000 Hz | 4.4 dBmV | 41.8 dB | 52747936 | 0 | 0 |
| 9 | Locked | QAM256 | 8 | 561000000 Hz | 4.0 dBmV | 41.3 dB | 52751646 | 0 | 0 |
| 10 | Locked | QAM256 | 9 | 567000000 Hz | 4.3 dBmV | 41.4 dB | 52755816 | 0 | 0 |
| 11 | Locked | QAM256 | 10 | 573000000 Hz | 4.8 dBmV | 41.0 dB | 52759463 | 0 | 0 |
| 12 | Locked | QAM256 | 11 | 579000000 Hz | 4.5 dBmV | 41.7 dB | 52762517 | 0 | 0 |
| 13 | Locked | QAM256 | 12 | 585000000 Hz | 4.1 dBmV | 41.7 dB | 52766482 | 0 | 0 |
| 14 | Locked | QAM256 | 13 | 591000000 Hz | 4.2 dBmV | 41.6 dB | 52770266 | 0 | 0 |
| 15 | Locked | QAM256 | 14 | 597000000 Hz | 4.1 dBmV | 41.5 dB | 52773606 | 0 | 0 |
| 16 | Locked | QAM256 | 15 | 603000000 Hz | 4.2 dBmV | 41.4 dB | 52777257 | 0 | 0 |
| 17 | Locked | QAM256 | 16 | 609000000 Hz | 3.6 dBmV | 41.3 dB | 52781205 | 0 | 0 |
| 18 | Locked | QAM256 | 17 | 615000000 Hz | 3.5 dBmV | 41.4 dB | 52784768 | 0 | 0 |
| 19 | Locked | QAM256 | 18 | 621000000 Hz | 3.4 dBmV | 41.2 dB | 52788545 | 0 | 0 |
| 20 | Locked | QAM256 | 19 | 627000000 Hz | 2.7 dBmV | 41.0 dB | 52792360 | 0 | 0 |
| 21 | Locked | QAM256 | 20 | 633000000 Hz | 2.6 dBmV | 41.2 dB | 52796175 | 0 | 0 |
| 22 | Locked | QAM256 | 21 | 639000000 Hz | 1.9 dBmV | 40.9 dB | 52799876 | 0 | 0 |
| 23 | Locked | QAM256 | 22 | 645000000 Hz | 2.2 dBmV | 41.0 dB | 52803281 | 0 | 0 |
| 24 | Locked | QAM256 | 23 | 651000000 Hz | 1.6 dBmV | 40.8 dB | 52807173 | 0 | 0 |
| 25 | Locked | QAM256 | 24 | 657000000 Hz | 1.3 dBmV | 40.7 dB | 52811317 | 0 | 0 |
| 26 | Locked | QAM256 | 25 | 663000000 Hz | 1.1 dBmV | 40.4 dB | 52814649 | 0 | 0 |
| 27 | Locked | QAM256 | 26 | 669000000 Hz | 1.1 dBmV | 40.3 dB | 52818368 | 0 | 0 |
| 28 | Locked | QAM256 | 27 | 675000000 Hz | 1.4 dBmV | 38.7 dB | 52822178 | 0 | 0 |
| 29 | Locked | QAM256 | 28 | 681000000 Hz | 1.2 dBmV | 40.4 dB | 52823754 | 0 | 0 |
| 30 | Locked | QAM256 | 29 | 687000000 Hz | 1.6 dBmV | 40.5 dB | 52825078 | 0 | 0 |
| 31 | Locked | QAM256 | 30 | 699000000 Hz | 1.5 dBmV | 40.5 dB | 52826182 | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
| 1 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 2 | Locked | ATDMA | 2 | 24200000 Hz | 41.8 dBmV |
| 3 | Locked | ATDMA | 3 | 30600000 Hz | 42.5 dBmV |
| 4 | Locked | ATDMA | 4 | 37000000 Hz | 41.3 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV |
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0, 1, 2, 255 | 33 | 380000000 Hz | 8.4 dBmV | 40.8 dB | 1108 ~ 2987 | 137994585 | 118978478 | 0 |
| 2 | Not Locked | 0, 255 | 0 | 0 Hz | 4.1 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
| 1 | Locked | 3, 4, 12, 13 | 1 | 1800000 Hz | 40.0 dBmV |
| 2 | Not Locked | 3, 4, 12, 13 | 0 | 0 Hz | 0.0 dBmV |
- Madlad90046Aspirant
Here's my event log...
Time Priority Description 2020-09-22, 05:04:04 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; 2020-09-22, 05:03:47 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 13 ; New Profile: 12 13 .;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; 2020-09-22, 05:03:40 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 .;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; 2020-09-22, 05:03:31 Notice (6) TLV-11 - unrecognized OID;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; 2020-09-22, 05:03:31 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; 2020-09-22, 05:03:31 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4 Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2020-09-22, 04:46:56 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Ranging Request Retries exhausted;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Ranging Request Retries exhausted;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Ranging Request Retries exhausted;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Ranging Request Retries exhausted;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Ranging Request Retries exhausted;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) Ranging Request Retries exhausted;CM-MAC=bc:a5:11:7f:ab:3c;CMTS-MAC=00:01:5c:66:06:47;CM-QOS=1.1;CM-VER=3.1; - plemansGuru - Experienced User
Do you have any splitters, attenuators, or amplifiers in line? if so, remove them.
check all the connectors for loose/cheap/bad connections. Check the coax cable for kinks, damage, corrosion, etc.
Preferrably, move the modem to right where the coax enters the home to prevent the wiring within the home being the issue.
try it there.
If it doesn't help, the isp needs to check the line based off your logs and cable connection info.
