betty23's avatar
betty23
CM1000 v2 only 16 channels locked, 400 mbps on 1 gig service
Dear all-
I've been reading other threads on this forum though I don't feel confident about reading the power levels, etc.  I have a CM1000 v2, RCN 1 Gig service.  I don't exceed 400Mbps though.
My logs are empty - no errors or anything like that.  However, I've noticed that only 16/32 channels are locked.  Shouldn't 32 be locked? or at least more than 16?
I took the modem outside of the house and connected it directly to the RCN line.  Tested both outside with a cat 6 cable on a 1 gig ethernet port yields the same result as testing inside my home via my router on another computer - 400 mpbs max.  I've reset the modem using the button on the back and by using the software interface.  No difference.
I've called RCN - they tell me the only thing they can do is send out a technician.  On the RCN speed test website it does say that I have 1000 Mbps service.  I'm just not getting that speed.  Does anyone have any advice?
I've attached the power levels page.  Your expertise would be greatly appreciated!!
Thank you!
betty
1 Reply
  • plemans's avatar
    I've had people over the phone send the wrong provisioning before. You can attempt to have them re-provision it.
    The best bet though is the technician coming out. You're levels are a bit out of spec but not horrible. You only want around 3.5dbmv (roughly) between your channels. Of those that are locked, you go from 1.1 to -4.7dbmv. so a 5.8dbmv difference. Plus with the channels not locking, havin a technician check the line is important.
    I think the tech on the phone saying you're pulling full speed is a bit fos (full of s**t). :)
    what website are you using for speedtesting?
    I've found ookla has struggled to find a server to saturate gigabit at times. try several different sites/servers to test on.
