CTokkie
Dec 31, 2017Aspirant
Cm1000 Warning Message
So I logged into my Modem and i see this in the logs. RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=b0:39:56:4c:57:58;CMTS-MAC=00:b0:e1...
thunt002
Jan 02, 2018Tutor
I am having the same issue with Comcast. Unstable internet since Christmas with the same error messages as OP. They told me that it is a Netgear firmware issue. Hoping for a resolution soon.
Internet seems to work fine with modem factory reset for a few hours before reverting back to prior unstable state of frequent disconnects and dial-up download speeds.
vkdelta
Jan 03, 2018NETGEAR Employee Retired
Please post your logs and FW version.
you should be on latest 3.01.04 FW version. this was rolled out just before christmas.
- CTokkieJan 03, 2018Aspirant
My ISP is actually Cox Cable
From the screenshot i posted looks like i'm on 3.01.02
Here's another screen shot of my logs, I don't see anywhere to perform a firm ware update
- vkdeltaJan 03, 2018NETGEAR Employee Retired
Cox will need to Push the FW.
We have already provided new FW to Cox and they have not yet certified/push to their customers. There are several DOCSIS fixes in the new FW and I hope Cox will push to their customers very soon.
Can you please call Cox and plead them to push new FW?
Additionally, it would help you send me your CM MAC and account # (PM me in the info and dont post it publicly here) and I will check with Cox contacts if they can do a temp push to just your modem?
Which account number? My cox account number?
- thunt002Jan 03, 2018Tutor
I have the latest firmware. First of 3 pages of error logs are attached.
thanks for the logs. there is possibility that your RF signal has lot of tilt in it and it is causing these communication between CM and CMTS.
which ISP/location?
Please post the power table as well.
I have Xfinity/Comcast in St. Paul, MN. We have 200 mb/s download plan. Please tell me where I can locate the power table.
