Ron-Richardson
Aug 30, 2018Aspirant
CM1000 Xfinity - Upload Speeds
Just installed the CM1000 (to wired desktop) and I have Xfinity's 250M down / 10M up. When I run the Xfinity speed test, I get about 280M / 11M. That looks great. Then I upload files via FTP or ...
vkdelta
Aug 30, 2018NETGEAR Employee Retired
is it 1.4MBps or 1.4 Mbps?
It might be cPanel limitation or you need to put multiple transfer threads in the FTP tool.
Ron-Richardson
Aug 31, 2018Aspirant
It's 1.4MB. Rookie mistake. And, now I see that speedtests are in Mb. So, that mystery solved. I am getting the upload speed that I should.
But, I'm intrigued.... "multiple transfer threads in the FTP" ? I'm using WinSCP. Is that a feature of the FTP program or modem? BTW, on Win 10.
- vkdeltaAug 31, 2018NETGEAR Employee Retired
yes, lot of folks forget MB vs Mb.
not sure if winSCP supports it.
https://winscp.net/tracker/513
you are using SFTP and not traditional FTP.
I believe Filezilla supports using FTP.
