jgnoonan
Dec 03, 2017Star
CM1000 Xfinity issues
I am quite frustrated at this point. I had a CM600 modem to support Comcast's Extreme 150 service. I've had it for a few years and was consistently getting 160 to 170mbps speed from it. About thre...
- Mar 12, 2018
Well it is finally fixed. The tech showed up today and I showed him the two frequencies that were having the problem. He checked outside, and then at the tap. He came into the house and said he needed to call a bucket truck in to fix it. I got a recorded call from Comcast that they were working to fix the issue. I got a second call an hour later that the issue was fixed. I ran a speed test and got a consistent 160mbps (yay!). I used the reset button on the modem and let it re-provision. All the signal/noise and power levels were good and there were no uncorrectable codewords. They didn't tell me what they fixed, but at long last, it is fixed.
Slpope99
Feb 21, 2018Aspirant
Same issue. I just upgraded to gigabit speed and I cant get more than 400mb down. As the day goes on my speed gets less and less until I reboot. I'm on the latest firmware. I've connect the modem direct to my pc using cat6 and I cant get full speed.
I've called comcast and they reposted the provision with no avail.
- vkdeltaFeb 21, 2018NETGEAR Employee Retired
- Slpope99Feb 21, 2018Aspirant
Time Priority Description 2018-02-21, 21:00:29 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 .;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:01:5c:81:9a:5e;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:01:5c:81:9a:5e;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-02-21, 20:59:21 Critical (3) Resetting the cable modem due to docsDevResetNow Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:01:5c:81:9a:5e;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-02-21, 20:48:19 Critical (3) Resetting the cable modem due to docsDevResetNow Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:01:5c:81:9a:5e;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:01:5c:81:9a:5e;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:b9:8a:af:7e:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
<tabindex=-1>Startup Procedure Procedure Status Comment Acquire Downstream Channel 519000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Enable BPI+ IP Provisioning Mode Honor MDD IPv6 only <tabindex=-1>Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR / MER Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked QAM256 1 519000000 Hz 3.0 dBmV 41.3 dB 256253426 0 0 2 Locked QAM256 2 525000000 Hz 3.0 dBmV 41.3 dB 256354703 0 0 3 Locked QAM256 3 531000000 Hz 3.3 dBmV 41.2 dB 256363832 5 0 4 Locked QAM256 4 537000000 Hz 3.4 dBmV 41.3 dB 256372448 0 0 5 Locked QAM256 5 543000000 Hz 3.2 dBmV 41.3 dB 256382017 6 0 6 Locked QAM256 6 549000000 Hz 2.9 dBmV 41.1 dB 256391731 5 0 7 Locked QAM256 7 555000000 Hz 2.8 dBmV 40.9 dB 256399687 0 0 8 Locked QAM256 8 561000000 Hz 3.3 dBmV 40.9 dB 256387553 0 0 9 Locked QAM256 9 567000000 Hz 2.7 dBmV 40.7 dB 256420638 0 0 10 Locked QAM256 10 573000000 Hz 2.8 dBmV 40.8 dB 256429386 0 0 11 Locked QAM256 11 579000000 Hz 3.3 dBmV 38.8 dB 256439486 0 0 12 Locked QAM256 12 585000000 Hz 3.3 dBmV 39.7 dB 256448391 0 0 13 Locked QAM256 13 591000000 Hz 3.5 dBmV 40.3 dB 256458340 0 0 14 Locked QAM256 14 597000000 Hz 3.1 dBmV 40.4 dB 256467361 0 0 15 Locked QAM256 15 603000000 Hz 3.6 dBmV 40.5 dB 256476587 0 0 16 Locked QAM256 16 609000000 Hz 3.2 dBmV 40.5 dB 256494261 0 0 17 Locked QAM256 17 615000000 Hz 3.0 dBmV 40.3 dB 256504165 0 0 18 Locked QAM256 18 621000000 Hz 3.5 dBmV 40.4 dB 256513574 0 0 19 Locked QAM256 19 627000000 Hz 3.7 dBmV 39.7 dB 256523609 0 0 20 Locked QAM256 20 633000000 Hz 4.4 dBmV 40.3 dB 256531881 0 0 21 Locked QAM256 21 639000000 Hz 4.6 dBmV 38.9 dB 256541262 0 0 22 Locked QAM256 22 645000000 Hz 4.6 dBmV 37.2 dB 256545778 0 0 23 Locked QAM256 23 651000000 Hz 4.7 dBmV 35.9 dB 256551433 0 0 24 Locked QAM256 24 657000000 Hz 4.2 dBmV 37.8 dB 256556670 0 0 25 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 26 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 27 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 28 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 29 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 30 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 31 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 0 <tabindex=-1>Upstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power 1 Locked ATDMA 1 35800000 Hz 43.8 dBmV 2 Locked ATDMA 2 29400000 Hz 43.3 dBmV 3 Locked ATDMA 3 23000000 Hz 42.5 dBmV 4 Not Locked Unknown 0 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Hz 0.0 dBmV <tabindex=-1>Downstream OFDM Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power SNR / MER Active Subcarrier Number Range Unerrored Codewords Correctable Codewords Uncorrectable Codewords 1 Locked 0, 1 25 708000000 Hz 4.2 dBmV 36.0 dB 1108 ~ 2987 26207888 18164935 0 2 Not Locked 0 0 0 Hz 2.0 dBmV 0.0 dB 0 ~ 4095 0 0 0 <tabindex=-1>Upstream OFDMA Channels Channel Lock Status Modulation / Profile ID Channel ID Frequency Power 1 Not Locked Unknown 0 0 Hz 0 dBmV 2 Not Locked Unknown 0 0 Hz 0 dBmV Hardware Version 2.02 Firmware Version V3.01.04 Cable Modem Serial Number Removed CM certificate Installed CM MAC b0:b9:8a:af:7e:28 - vkdeltaFeb 22, 2018NETGEAR Employee Retired
pls post it as screenshot linked to imgur.com or some other site as your columns got cutoff. I cannot see how many uncorrectables in each channel.
