jgnoonan
Dec 03, 2017Star
CM1000 Xfinity issues
I am quite frustrated at this point. I had a CM600 modem to support Comcast's Extreme 150 service. I've had it for a few years and was consistently getting 160 to 170mbps speed from it. About thre...
- Mar 12, 2018
Well it is finally fixed. The tech showed up today and I showed him the two frequencies that were having the problem. He checked outside, and then at the tap. He came into the house and said he needed to call a bucket truck in to fix it. I got a recorded call from Comcast that they were working to fix the issue. I got a second call an hour later that the issue was fixed. I ran a speed test and got a consistent 160mbps (yay!). I used the reset button on the modem and let it re-provision. All the signal/noise and power levels were good and there were no uncorrectable codewords. They didn't tell me what they fixed, but at long last, it is fixed.
NBCGLX
Mar 28, 2018Guide
martyr444wrote:NBCGLXYour upstream power is way to high and your downstream power could be closer to zero.
Thanks. How does one fix that?
vkdelta
Mar 29, 2018NETGEAR Employee Retired
do you have lot of attenuators or splitters at home?
- NBCGLXMar 30, 2018Guide
vkdeltawrote:do you have lot of attenuators or splitters at home?
The main coax line comes into the garage where, via a splitter, it feeds all the coax outlets in the house. Each coax outlet has a unique line from the main splitter in the garage. Regarding the outlet that the modem is plugged into, I had two, two-way splitters on it: one with an output to the modem and an output to the input of the second two-way splitter, and the second two-way splitter had one line to a cable box and one line to a bonded MoCA 2.0 adapter for our MoCA network. We actually got rid of the cable box, so I removed that splitter and now the coax outlet only has one, two-way splitter: one output feeds the modem and one output feeds the MoCA adapter. I'm not sure what you mean by attenuators, but we do have two POE filters on our coax, one at the main line into the garage to be sure our MoCA network doesn't leave the house, and a second attached directly to the modem because I was advised that modems don't appreciate being bombarded by the electronic traffic the MoCA network generates. Below are links to pics of updated screenshots of the cable connection. Power issues seem to have gotten worse!
- vkdeltaApr 02, 2018NETGEAR Employee Retired
power levels are still bad (though I dont see uncorrectables and that may be because you did not the run traffic for a while).
what is the your power level at the coax entry point in your home?
Have you tried using active return path? (these are tricky as some of them distort signal and even make it worse).
Have you tried asking to remove attenuation outside your house so you can boost your signal level? (typically at the node at the street).
- MattNApr 03, 2018Tutor
Power levels are "bad" => What are examples of good and bad power levels? Please writeup some docs on how to self-diagnose this stuff, would be useful. What are bad levels of errors? What do the specific error messages mean in the log, etc..
- DahbehrApr 04, 2018AspirantCan anyone explain this? Comcast came out today and hooked up their XB6 modem and poof worked fine. I was watching YouTube last night and the internet just cut out immediately and haven’t been able to fix it. The modem downstream and upstream lights both turn solid then the internet blinks. It seems to time out then repeat this process over and over. Comcast says the modem is bad. The modem is less than two weeks old. This is very frustrating because nobody seems to know what’s going on and I don’t want to pay Comcast $10 a month. Firmware is update also. When I go into the log files they all just say dhcp failed or synchronization failure.
If anyone has an idea what’s happening that would be great. - DahbehrApr 04, 2018AspirantCorrect. Comcast can’t even see the modem is online so they can’t even troubleshoot it. It was working fine until yesterday afternoon when it abruptly stopped.
- vkdeltaApr 04, 2018NETGEAR Employee Retired
DHCPv6 server from comcast is not responding (have seen this happening when there was an outage in an area).
how long have you seen this? or it just started happening.
where are you located?
- DahbehrApr 04, 2018AspirantIt just started yesterday around 2pm cst. Located in St. Paul, Minnesota. They hooked up their own modem and that works fine. I just don’t want to get stuck paying them $10/ month to rent a modem. So it doesn’t appear to be an outage issue.
- NBCGLXApr 04, 2018Guide
vkdeltawrote:power levels are still bad (though I dont see uncorrectables and that may be because you did not the run traffic for a while).
How would I know the power level at the entry point?
What is active return path?
No, haven't asked Comcast to remove attenuation outside our home to boost our signal level. Remember, they're convinced the service is just fine and it's the modem that's the problem.
- taichiApr 21, 2018Tutor
I ran into the same problem and spent 4 hours with both Netgear and comcast rep. It doesnt go anywhere as comcast said it's modem and netgear said comcast with cable line with noises/traffic. reset model, power up/down.... not sure I want to go with diffent brand of modem
2018-04-20, 22:50:18 Notice (6) CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: ; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 22:50:18 Warning (5) Unicast DSID PSN startup error 2018-04-20, 22:47:41 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 22:41:33 Critical (3) Resetting the cable modem due to docsDevResetNow Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 18:31:17 Critical (3) Resetting the cable modem due to docsDevResetNow Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:55:24 Critical (3) Resetting the cable modem due to docsDevResetNow 2018-04-20, 08:45:06 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:34:41 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:34:36 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:34:17 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:34:16 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:33:57 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:33:56 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:33:37 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:33:36 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:32:58 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:32:52 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:32:49 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:31:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:31:33 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:31:13 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:31:13 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:30:53 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:30:53 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:30:33 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:30:33 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:29:59 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; - NBCGLXApr 22, 2018Guide
Yeah, Comcast is a horrible company and they're always looking to place blame elsewhere. Not my cables. Not my service. It's YOUR equipment that's the problem! So tired of this BS. I feel like the only way this will be solved will be to fork out the money to get Comcast's stupid modem/gateway or whatever they call it and prove to them that I still can't get anything close to the gigabit speeds I'm paying for. It's infuriating.
- jgnoonanApr 22, 2018Star
Your upstream power levels are WAY too high. Look at the second image you posted. Look at the three upstream channels under power. All three are around 59 and they should be about 30-35. This is a COMCAST issue. I just called them they other day and I told them what to look at and they found that it was not just my house but 7 other houses with the issue. You need to tell them what to do. If they send someone to the house, show them those three channels. Ask that they look on the tap to see if it's the same out at the street. If it is, it's their problem. If it isn't, then it's a cabling issue. My internet drops out like 4 times a day. They replaced every cable from the tap to the modem including trenching a new cable under my yard. It is not the NetGear modem. It's a wayward amp or connection somewhere in the system. You have to be persistent with them. Don't give up. I actually ended up getting a call from Corporate because I am now labeled a "chronic" customer.
Post your modem connection page. Look at the downstream power levels. Are there any channels with a very high number of uncorrectable codewords? By high I mean millions or billions. If you can post that full page here, the community can better assist. BTW, these issues seem to be almost always COMCAST issues not NetGear issues, but you have to tell them specifically what is wrong. It will usually mean a trip to the house by a tech. I work at home so it's no big deal but for others, that can be a pain in the butt.
jgnoonan wrote:Post your modem connection page. Look at the downstream power levels. Are there any channels with a very high number of uncorrectable codewords? By high I mean millions or billions. If you can post that full page here, the community can better assist. BTW, these issues seem to be almost always COMCAST issues not NetGear issues, but you have to tell them specifically what is wrong. It will usually mean a trip to the house by a tech. I work at home so it's no big deal but for others, that can be a pain in the butt.
I have mine posted above, but here they are again:
I don't know to get them to show inline with the post.
- MrgoodallApr 24, 2018Star
CM1000 statusIs this right after a boot and a reset of the modem? Because mine looks nothing like that.
- NBCGLXApr 27, 2018Guide
DarrenM wrote:
Hello NBCGLX
You levels seem to be off a little low on the downstream and high on the upstream do you have any splitter connected
Mrgoodall You look to have some uncorrectables are you seeing any timeouts in your logs.
DarrenM
One splitter where the main line comes into the garage that feeds 4 coax outlets in the house. One of the outlets feeds another splitter, which feeds the modem and a MoCA 2.0 bonded adapter for our MoCA network.
- DarrenMMay 02, 2018Sr. NETGEAR Moderator
You may want a ISP tech to come out and check the levels on your lines.
DarrenM
- MrgoodallMay 04, 2018Star
they dispatched a tech, he looked and saw it was a indeed a line quality issue, had to scheudle a line tech to complete maintence. based solely on signal quality, he showed me his readings, they showed "DOCSIS Failure". 7-10 business days until line tech completes work.
- MattNMay 04, 2018Tutor
I wonder why these cable modems are not smart enough to detect line signal issues and let the user know? Seems like an easy to add feature that would be useful for customer.
- MrgoodallMay 05, 2018StarIt could be that different cable systems provision via different methods and systems. Adding features like automated reporting to non-compatible systems could real havoc on an ever changing platform. Remember, each isp provisions the modems to their system. It may not be in their interest to support a product that they don’t sell/bill for.
