jgnoonan
Dec 03, 2017Star
CM1000 Xfinity issues
I am quite frustrated at this point. I had a CM600 modem to support Comcast's Extreme 150 service. I've had it for a few years and was consistently getting 160 to 170mbps speed from it. About thre...
- Mar 12, 2018
Well it is finally fixed. The tech showed up today and I showed him the two frequencies that were having the problem. He checked outside, and then at the tap. He came into the house and said he needed to call a bucket truck in to fix it. I got a recorded call from Comcast that they were working to fix the issue. I got a second call an hour later that the issue was fixed. I ran a speed test and got a consistent 160mbps (yay!). I used the reset button on the modem and let it re-provision. All the signal/noise and power levels were good and there were no uncorrectable codewords. They didn't tell me what they fixed, but at long last, it is fixed.
vkdelta
Apr 01, 2018NETGEAR Employee Retired
power levels are still bad (though I dont see uncorrectables and that may be because you did not the run traffic for a while).
what is the your power level at the coax entry point in your home?
Have you tried using active return path? (these are tricky as some of them distort signal and even make it worse).
Have you tried asking to remove attenuation outside your house so you can boost your signal level? (typically at the node at the street).
NBCGLX
Apr 04, 2018Guide
How would I know the power level at the entry point?
What is active return path?
No, haven't asked Comcast to remove attenuation outside our home to boost our signal level. Remember, they're convinced the service is just fine and it's the modem that's the problem.
- taichiApr 20, 2018Tutor
I ran into the same problem and spent 4 hours with both Netgear and comcast rep. It doesnt go anywhere as comcast said it's modem and netgear said comcast with cable line with noises/traffic. reset model, power up/down.... not sure I want to go with diffent brand of modem
2018-04-20, 22:50:18 Notice (6) CM-STATUS message sent. Event Type Code: 3; Chan ID: N/A; DSID: ; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 22:50:18 Warning (5) Unicast DSID PSN startup error 2018-04-20, 22:47:41 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6 Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 22:41:33 Critical (3) Resetting the cable modem due to docsDevResetNow Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 18:31:17 Critical (3) Resetting the cable modem due to docsDevResetNow Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:55:24 Critical (3) Resetting the cable modem due to docsDevResetNow 2018-04-20, 08:45:06 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:34:41 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:34:36 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:34:17 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:34:16 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:33:57 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:33:56 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:33:37 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:33:36 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:32:58 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:32:52 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 08:32:49 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:31:38 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:31:33 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:31:13 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:31:13 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:30:53 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:30:53 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:30:33 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:30:33 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; 2018-04-20, 07:29:59 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=b0:39:56:9c:67:41;CMTS-MAC=00:9e:1e:58:d4:ef;CM-QOS=1.1;CM-VER=3.1; - NBCGLXApr 22, 2018Guide
Yeah, Comcast is a horrible company and they're always looking to place blame elsewhere. Not my cables. Not my service. It's YOUR equipment that's the problem! So tired of this BS. I feel like the only way this will be solved will be to fork out the money to get Comcast's stupid modem/gateway or whatever they call it and prove to them that I still can't get anything close to the gigabit speeds I'm paying for. It's infuriating.
- jgnoonanApr 22, 2018Star
Post your modem connection page. Look at the downstream power levels. Are there any channels with a very high number of uncorrectable codewords? By high I mean millions or billions. If you can post that full page here, the community can better assist. BTW, these issues seem to be almost always COMCAST issues not NetGear issues, but you have to tell them specifically what is wrong. It will usually mean a trip to the house by a tech. I work at home so it's no big deal but for others, that can be a pain in the butt.
jgnoonan wrote:Post your modem connection page. Look at the downstream power levels. Are there any channels with a very high number of uncorrectable codewords? By high I mean millions or billions. If you can post that full page here, the community can better assist. BTW, these issues seem to be almost always COMCAST issues not NetGear issues, but you have to tell them specifically what is wrong. It will usually mean a trip to the house by a tech. I work at home so it's no big deal but for others, that can be a pain in the butt.
I have mine posted above, but here they are again:
I don't know to get them to show inline with the post.
- MrgoodallApr 24, 2018Star
CM1000 statusIs this right after a boot and a reset of the modem? Because mine looks nothing like that.
- NBCGLXApr 27, 2018Guide
DarrenM wrote:
Hello NBCGLX
You levels seem to be off a little low on the downstream and high on the upstream do you have any splitter connected
Mrgoodall You look to have some uncorrectables are you seeing any timeouts in your logs.
DarrenM
One splitter where the main line comes into the garage that feeds 4 coax outlets in the house. One of the outlets feeds another splitter, which feeds the modem and a MoCA 2.0 bonded adapter for our MoCA network.
- DarrenMMay 02, 2018Sr. NETGEAR Moderator
You may want a ISP tech to come out and check the levels on your lines.
DarrenM
- MrgoodallMay 04, 2018Star
they dispatched a tech, he looked and saw it was a indeed a line quality issue, had to scheudle a line tech to complete maintence. based solely on signal quality, he showed me his readings, they showed "DOCSIS Failure". 7-10 business days until line tech completes work.
- MattNMay 04, 2018Tutor
I wonder why these cable modems are not smart enough to detect line signal issues and let the user know? Seems like an easy to add feature that would be useful for customer.
- MrgoodallMay 04, 2018StarIt could be that different cable systems provision via different methods and systems. Adding features like automated reporting to non-compatible systems could real havoc on an ever changing platform. Remember, each isp provisions the modems to their system. It may not be in their interest to support a product that they don’t sell/bill for.
