jgnoonan
Dec 03, 2017Star
CM1000 Xfinity issues
I am quite frustrated at this point. I had a CM600 modem to support Comcast's Extreme 150 service. I've had it for a few years and was consistently getting 160 to 170mbps speed from it. About thre...
- Mar 12, 2018
Well it is finally fixed. The tech showed up today and I showed him the two frequencies that were having the problem. He checked outside, and then at the tap. He came into the house and said he needed to call a bucket truck in to fix it. I got a recorded call from Comcast that they were working to fix the issue. I got a second call an hour later that the issue was fixed. I ran a speed test and got a consistent 160mbps (yay!). I used the reset button on the modem and let it re-provision. All the signal/noise and power levels were good and there were no uncorrectable codewords. They didn't tell me what they fixed, but at long last, it is fixed.
NBCGLX
Apr 22, 2018Guide
jgnoonan wrote:Post your modem connection page. Look at the downstream power levels. Are there any channels with a very high number of uncorrectable codewords? By high I mean millions or billions. If you can post that full page here, the community can better assist. BTW, these issues seem to be almost always COMCAST issues not NetGear issues, but you have to tell them specifically what is wrong. It will usually mean a trip to the house by a tech. I work at home so it's no big deal but for others, that can be a pain in the butt.
I have mine posted above, but here they are again:
I don't know to get them to show inline with the post.
DarrenM
Apr 27, 2018Sr. NETGEAR Moderator
Hello NBCGLX
You levels seem to be off a little low on the downstream and high on the upstream do you have any splitter connected
Mrgoodall You look to have some uncorrectables are you seeing any timeouts in your logs.
DarrenM
- NBCGLXApr 27, 2018Guide
DarrenM wrote:
Hello NBCGLX
DarrenM
One splitter where the main line comes into the garage that feeds 4 coax outlets in the house. One of the outlets feeds another splitter, which feeds the modem and a MoCA 2.0 bonded adapter for our MoCA network.
- DarrenMMay 02, 2018Sr. NETGEAR Moderator
You may want a ISP tech to come out and check the levels on your lines.
DarrenM
- MrgoodallMay 04, 2018Star
they dispatched a tech, he looked and saw it was a indeed a line quality issue, had to scheudle a line tech to complete maintence. based solely on signal quality, he showed me his readings, they showed "DOCSIS Failure". 7-10 business days until line tech completes work.
- MattNMay 04, 2018Tutor
I wonder why these cable modems are not smart enough to detect line signal issues and let the user know? Seems like an easy to add feature that would be useful for customer.
- MrgoodallMay 04, 2018StarIt could be that different cable systems provision via different methods and systems. Adding features like automated reporting to non-compatible systems could real havoc on an ever changing platform. Remember, each isp provisions the modems to their system. It may not be in their interest to support a product that they don’t sell/bill for.
