savvy_surfer
Sep 11, 2019Follower
CM1000 Xfinity issues
Experiencing similar issues as mentioned in - https://community.netgear.com/t5/Cable-Modems-Routers/CM1000-Xfinity-issues/td-p/1445693 I've had xifinity for an year without issues and then right ...
Sep 11, 2019Guru - Experienced User
Make sure there are no coax cable line splitters between the ISP service box and the modem.
Contact the ISP have have them ensure the signal and quality is good up to the modem.
Swap LAN cables when testing directly to the modem with a wired PC.
If the modem has been working fine up to a certain point then it doesn't, I presume this would be a ISP service line issue.
