DMM39's avatar
DMM39
Follower
Sep 08, 2018
CM1000
Can I use my iPhone to setup my modem
1 Reply
  •    My cable-TV modem experience is minimal, but...
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Install Your
    Cable Modem and Connect It to a Computer".  Clearly, the instructions
    suggest using a wired connection from a computer directly to the modem.
       If you read further, down to "Connect Your Cable Modem to a Router
    After Installation and Activation", you may see:
          During the installation and activation, you must connect the cable
          modem directly to a computer. After installation and activation,
          you can connect the cable modem to a router.
       You could try connecting a wireless router to the modem before "the
    installation and activation" are complete, and see what (if anything)
    you can do at "http://192.168.100.1".
       Alternatively, obtain (borrow/buy/rent/steal/...) a computer with an
    Ethernet interface.
