Legacy11's avatar
Legacy11
CM1000v.2 mod Ipv setting needs to be changed from Ipv4 to Ivp6
I recently had to do a factor reset to my CM1000v.2.  Prior to the reset it was set to Ipv6.  Now it is set to Ipv4.  How do I set it back to Ipv6?
Thanks in advance for your help.
  • FURRYe38's avatar
    There is no configuration changes with in the CM series modems for IPv#. All CM series modems pass thru both protocols to an external connecting device like a external router system that does have configuration features for IPv6 configurations. Check with the router connected to the CM modem for these features.
