gavin1425
May 07, 2025Follower
CM1000v2 and Rax-5
My CM1000v2 modem will not connect to my Rax-5 router. Both are new
What error do you get?
Can you log into the modem while its connected to the router? (go to 192.168.100.1)
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed?
Turn off and unplug modem.
Turn on computers and rest of network.Be sure your using a good quality LAN cable between the modem and router. CAT6 UTP is recommended.
Make sure the modem is activated with the ISP first.
Walk thru a setup wizard using a PC and web browser to set up the router: https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
