nsayer's avatar
nsayer
CM1000v2 Will not boot
We had this exact same thing happen. Xfinity had a multi-day outage, and part way through we discovered that our modem had the all-lights-blink problem.
We called Netgear support and they told us to pound sand because the unit was 13 months old and the warranty was 12 months.
I am 99.999% sure that the problem is that the firmware is corrupt and simply reflashing it would bring it back, but Netgear seems to be unwilling to actually do this, preferring instead to just generate more eWaste. What a shame.
    If you actually have the CM1000v2 like the title says, it is a cable modem.  Refreshing the firmware is at the sole discretion of the ISP, not the cable modem manufacturer.
    If you ask technical support at Xfinity, they should refresh your firmware for you.
    • nsayer's avatar
      nsayer
      Xfinity can’t reflash the firmware because the firmware corruption prevents booting at all.
      NETGEAR could reflash this unit with the original factory firmware. It’s foolish to suggest that they couldn’t do so if I mailed it back to them. But they simply won’t, preferring that I throw an otherwise perfectly useful cable modem into the trash because it missed the warranty window by 20 days.
      • FURRYe38's avatar
        With the ISP cable coax line disconnected, have you tried a 30-30-30 reset on the modem with nothing connected to it?
