J5150
Jan 29, 2019Aspirant
CM1100 Cable Modem NOT Charter/Spectrum Compatible
I'm pretty frustrated. Purchased a CM1100 cable modem from Costco.com because it shows Charter/Spectrum compatible... yet when I went to activate it - they say it's NOT compatible. Escalated to mul...
vkdelta
Jan 30, 2019NETGEAR Employee Retired
Ultra is just 400 Mbps speed. CM1100 should definitely work with it.
Do you have spectrum ticket#?
J5150
Jan 30, 2019Aspirant
I don’t. I escalated it through the call centers and through their social media as well. That’s when I got the callback. Would a trouble ticket help in this case? I can always try to get one. It seems other Spectrum users are experiencing the same issue based on other convos I’ve had. I’d be more than happy to escalate and get a trouble ticket if it would help.
- vkdeltaJan 30, 2019NETGEAR Employee Retired
Please get a trouble ticket.
We will send it our spectrum contacts.
- J5150Feb 06, 2019Aspirant
Sorry it took a couple of days to reply. I attempted to have the open a trouble ticket and simply got a reply of "this modem is not certified for that speed tier and there's no trouble ticket to open for an uncertified modem." I attempted to escalate and say that you all are wanting the info, but just got met with continuous refusal.
- Anzi_2019Mar 05, 2019Aspirant
Hi, I am exactly in the same boat as you (CM1100+GoogleWIFI+Spectrum). Wanted to see if you had any luck resolving this issue before I freshly starting a simillar post. Thanks.
- simmsbruApr 02, 2019Aspirant
Looking to go with the nighthawk CM1100. would like to know what the solutions were with this on Charter/Spectrum.
prior to ordering this modem, i like the idea of the 2 lan ports and thinking with this can split house into 2 subnets.
- antinodeApr 02, 2019Guru
> thinking with this can split house into 2 subnets.I'd ask my ISP what (if anything) I'd be able to do with that second
port.Why would two subnets be better than one for your usage?
- Mm530May 04, 2019Tutor
vkdelta,
i just bought this same modem from Costco. Would you be able to help me in getting this modem to be recognized on Spectrum’s system. I believe there are numerous other users out there having the same problem. Is there anyway that Netgear would reach out to Spectrum in resolving this. Thank you very much for your help
- FURRYe38May 06, 2019Guru - Experienced User
Mm530 wrote:
vkdelta,
