J5150
Jan 29, 2019Aspirant
CM1100 Cable Modem NOT Charter/Spectrum Compatible
I'm pretty frustrated. Purchased a CM1100 cable modem from Costco.com because it shows Charter/Spectrum compatible... yet when I went to activate it - they say it's NOT compatible. Escalated to mul...
vkdelta
Jan 31, 2019NETGEAR Employee Retired
Please get a trouble ticket.
We will send it our spectrum contacts.
simmsbru
Apr 02, 2019Aspirant
Looking to go with the nighthawk CM1100. would like to know what the solutions were with this on Charter/Spectrum.
prior to ordering this modem, i like the idea of the 2 lan ports and thinking with this can split house into 2 subnets.
- antinodeApr 02, 2019Guru
> thinking with this can split house into 2 subnets.I'd ask my ISP what (if anything) I'd be able to do with that second
port.Why would two subnets be better than one for your usage?
- simmsbruApr 03, 2019Aspirant
The purpose of using 2 subnets is to have one for the house and the family and the 2nd one for my office items as i do my jobs from home and tlike things split totaly apart and thought this might fit vs say hanging a Ubiqyiti edge router after modem to split things.
- vkdeltaApr 03, 2019NETGEAR Employee Retired
2 Ports WILL ONLY WORK FOR different IP, if your ISP supports multi-IP service.
Comcast supports it partially for residential and for Business customers.
If your ISP does not support MULTI-IP services, you can use only LAG for 2 ports.
