J5150
Jan 29, 2019Aspirant
CM1100 Cable Modem NOT Charter/Spectrum Compatible
I'm pretty frustrated. Purchased a CM1100 cable modem from Costco.com because it shows Charter/Spectrum compatible... yet when I went to activate it - they say it's NOT compatible. Escalated to mul...
Mm530
May 04, 2019Tutor
vkdelta,
i just bought this same modem from Costco. Would you be able to help me in getting this modem to be recognized on Spectrum’s system. I believe there are numerous other users out there having the same problem. Is there anyway that Netgear would reach out to Spectrum in resolving this. Thank you very much for your help
May 06, 2019Guru - Experienced User
Mm530 wrote:
vkdelta,
