netmask001's avatar
netmask001
CM1100 etherchannel
I am going to be using WAPs at home. how do I connect my CM1100 to the WAPS?
I want to connect the CM1100 to a cisco switch using a etherchannel.
Can the CM1100 do this?
Also can the CM1100 be a DHCP server for internal LAN?
Then I will put my WAPS on the cisco switch
is the CM1100 just a cable modem and router?
1 Reply
  • > is the CM1100 just a cable modem and router?
       Half right.  It's a modem. Hence there's no "router" in:
    > Model: CM1100|Nighthawk Multi-Gig Speed Cable Modem-DOCSIS 3.1
       "a cisco switch" is not a very detailed description of anything.
       Assuming that "a etherchannel" means an Ethernet cable, that's
    probably a bad idea.
       Add a router?
