Mako2350
Mar 27, 2019Aspirant
CM1100 setup with Google Wifi
I just purchased a CM1100 modem. Has anyone setup this modem with Google Wifi?
Mar 27, 2019Guru - Experienced User
I haven't but it should be like any other standard modem install. Get your CM1100 activated to your service, reboot the modem, hook up the google wifi to it, and then set up the google wifi. Are you having complications or problems doing so that we can help out with?
- Mako2350Mar 27, 2019Aspirant
I just got the modem today. The Google wifi is also new. I'll be setting it up this weekend. I will post about how it goes when I get everything working or if I have any issues.
Thanks for your help this evening.
- plemansMar 27, 2019Guru - Experienced UserNo worries. Thanks for messaging back. Just didn't know if you had specific concerns or not. Hope the install goes smoothly for you.
Congrats on the new setup!
