jthompson55's avatar
jthompson55
Follower
Apr 15, 2022
CM1100 Upstream light red
Upstream light is solid red. What do I need to do to turn it green.
  • Post a screensnip of the cable connections page and the event logs. Those help us more than just that you have a red light.
    It usually indicates a line issue though.
    Start with removing any amplifiers, signal attenuators, or splitters from the coax.
    From there check the line for kinks, damage, moisture in the line.
    Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
    If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
