aaronmcd1214's avatar
Feb 04, 2020
CM1100 will not accept more than one device
Trying to get my new modem setup and it appears that only 1 LAN port will provide internet access at a time. Called Cox to activate the modem and plugged my PC into it directly to test and everything worked. Then I tried plugging in my Orbi router to get it going but kept getting a 'no internet' connection error. Plugged my laptop into it directly and confirmed it would connect to the network (though I couldn't access the modem through it's IP) but no internet access. Tried resetting w/o the coax plugged in and it appeared to be working ok but the PC in the first port wasn't receiving internet now. Unplugged the laptop and reset, PC now has internet but 2nd port will not work. Is this just a defective unit perhaps?
  • No, its just a bad explaination by Cox and Netgear.
    the dual port on the cm1100 is designed for port aggregation (which most routers don't have) or for ISP's that allow multiple public IP addresses (most don't). I know comcast and cox don't allow it free. You can pay extra or get a business line that allows it but the standard setup doesn't.
    So for the average user, the 2nd port is useless.
    Try shutting off both the modem and router and disconnecting everything from the modem.
    Power the modem back on and give it a few minutes.
    then connect port 1 of modem to the wan port on the orbi.
    The power up the orbi. Give it a few minutes and then try going through setup.
  • plemans's avatar
    • aaronmcd1214's avatar
      aaronmcd1214
      Tutor
      Thanks for clarifying. My previous setup was with an Arris Surfboard combo unit that had 4 ports on the back and every device plugged into it worked. I'm assuming those were different then?
      • plemans's avatar
        It was problem a modem/router combo device.
        the CM1100 doesn't have an integrated router. Its a modem only device.
