greeno
Feb 03, 2024Apprentice
Cm1100 xfinity mid-split firmware needed
Hi netgear devs, When will a ‘mid-split’ capable firmware for xfinity be released to xfinity? I’m in such an area and my upload speeds are capped at 25Mbps. I’m paying for 100Mbps. Just need a netgea...
greeno
Thank you. I was having a hard time finding the right forum…yea this is a long shot, but I’m stuck until netgear provides a mid split firmware to xfinity…
michaelkenward
Feb 03, 2024Guru - Experienced User
You may be in for a long wait. That modem is now six years old. And hardware makers seem to have concluded that combined modem/routers are the way to go, even though experienced users don't like all in one boxes. Partly those is down to ISPs putting pressure on users to go down that road.
Does your ISP have a list of compatible modems?
Does Netgear offer a newer modem that meets your needs? If so, then at least you know that it understands the technology. If not it is likely to rewrite firmware for older models.
- greenoFeb 03, 2024ApprenticeRoger that. Hitron it is…
- michaelkenwardFeb 03, 2024Guru - Experienced User
One of the benefits of going "modem only" is that it should cost less and you can keep your existing router. And when you feel the urge, or if they change your Internet technology, you can buy whatever router you like.
- KitsapFeb 03, 2024Master
greeno wrote:
Roger that. Hitron it is…You will find some worthwhile information here:
https://www.dslreports.com/forum/r33821305-Equip-Xfinity-customers-with-CODA-CODA56-modems
