tgary
May 04, 2020Aspirant
CM1150V and AX6000 RBR850 internet connectivity issues with Xfinity
So frustrated with my new equipment and internet! Can anyone help? Dumped ATT, got Gig internet with Xfinity, and a CM1150V (for voip) with Orbi AX6000 RBR850 and RBS850 Satellite. Worked great for a week, then started dropping internet connectivity (across devices, including a computer with direct LAN to the RBRR850). I get weird behavior – for example, click to a website, get the frownie face (L website can’t be reached) then immediately loads. Commonly goes down completely overnight, and I have to reboot the modem. That fixes things a short while, then it starts again. Sometimes it works for up to three or four days; other times have to reboot multiple times daily. Had Xfinity techs out twice. First tech said everything should be good, but we took two steps to help: 1) he put a filter on a house downstream that he said was creating noise; and 2) changed it from a 3-way splitter (modem and two TV’s) to a 2-way, with the second splitter downstream for the second TV. Didn’t help. Second tech said lines are great to my modem – maybe try renting an Xfinity modem. (Would have done that out of the gate if I’d wanted to rent.)
When things work great, I can get 800-900 Mb even over wifi adjacent to the RBR850; 450 MB across the house through the satellite (on my phone). My hardwired computer is old, and tops out at about 250 Mb (which is fine – I figure that’s the computer). When it goes glitchy, I get long delays, then fast loading, then later slow speeds, then lose all connectivity.
CM1150V data seems good (SNR, power levels) with the possible exception of uncorrectibles on the OFDM download channel. When it goes completely down, event logs show the modem is not getting any response from Comcast, and it keeps rebooting. But a hard powercycle fixes it for a little while.
Here’s a screen shot of my channel data. (I can post the event logs if that is helpful.)
| Frequency start Value | |
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
Startup Procedure
| Procedure | Status | Comment |
| Acquire Downstream Channel | 531000000 Hz | Locked |
| Connectivity State | OK | Operational |
| Boot State | OK | Operational |
| Security | Enabled | BPI+ |
| IP Provisioning Mode | Honor MDD | honorMdd(4) |
Downstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
| 1 | Locked | QAM256 | 20 | 531000000 Hz | -3.2 dBmV | 38.7 dB | 0 | 0 |
| 2 | Locked | QAM256 | 17 | 513000000 Hz | -2.9 dBmV | 38.9 dB | 0 | 0 |
| 3 | Locked | QAM256 | 18 | 519000000 Hz | -2.9 dBmV | 38.9 dB | 0 | 0 |
| 4 | Locked | QAM256 | 19 | 525000000 Hz | -3.1 dBmV | 38.8 dB | 0 | 0 |
| 5 | Locked | QAM256 | 21 | 543000000 Hz | -3.3 dBmV | 38.8 dB | 0 | 0 |
| 6 | Locked | QAM256 | 22 | 549000000 Hz | -3.3 dBmV | 38.7 dB | 0 | 0 |
| 7 | Locked | QAM256 | 23 | 555000000 Hz | -3.8 dBmV | 38.5 dB | 0 | 0 |
| 8 | Locked | QAM256 | 24 | 561000000 Hz | -3.9 dBmV | 38.5 dB | 0 | 0 |
| 9 | Locked | QAM256 | 25 | 567000000 Hz | -3.9 dBmV | 38.6 dB | 0 | 0 |
| 10 | Locked | QAM256 | 26 | 573000000 Hz | -4.1 dBmV | 38.5 dB | 0 | 0 |
| 11 | Locked | QAM256 | 27 | 579000000 Hz | -4.4 dBmV | 38.4 dB | 0 | 0 |
| 12 | Locked | QAM256 | 28 | 585000000 Hz | -4.3 dBmV | 38.4 dB | 0 | 0 |
| 13 | Locked | QAM256 | 29 | 591000000 Hz | -4.1 dBmV | 38.4 dB | 0 | 0 |
| 14 | Locked | QAM256 | 30 | 597000000 Hz | -3.7 dBmV | 38.6 dB | 0 | 0 |
| 15 | Locked | QAM256 | 31 | 603000000 Hz | -3.4 dBmV | 38.6 dB | 0 | 0 |
| 16 | Locked | QAM256 | 32 | 609000000 Hz | -3.2 dBmV | 38.6 dB | 0 | 0 |
| 17 | Locked | QAM256 | 33 | 615000000 Hz | -3.2 dBmV | 38.5 dB | 0 | 0 |
| 18 | Locked | QAM256 | 34 | 621000000 Hz | -3.2 dBmV | 38.4 dB | 0 | 0 |
| 19 | Locked | QAM256 | 35 | 627000000 Hz | -3.2 dBmV | 38.5 dB | 0 | 0 |
| 20 | Locked | QAM256 | 36 | 633000000 Hz | -3.1 dBmV | 38.5 dB | 0 | 0 |
| 21 | Locked | QAM256 | 37 | 639000000 Hz | -3.1 dBmV | 38.5 dB | 0 | 0 |
| 22 | Locked | QAM256 | 38 | 645000000 Hz | -3.1 dBmV | 38.4 dB | 0 | 0 |
| 23 | Locked | QAM256 | 39 | 651000000 Hz | -3.1 dBmV | 38.3 dB | 0 | 0 |
| 24 | Locked | QAM256 | 40 | 657000000 Hz | -3.3 dBmV | 38.3 dB | 0 | 0 |
| 25 | Locked | QAM256 | 41 | 663000000 Hz | -3.4 dBmV | 38.3 dB | 0 | 0 |
| 26 | Locked | QAM256 | 42 | 669000000 Hz | -3.2 dBmV | 38.3 dB | 0 | 0 |
| 27 | Locked | QAM256 | 43 | 675000000 Hz | -2.9 dBmV | 38.1 dB | 0 | 0 |
| 28 | Locked | QAM256 | 44 | 681000000 Hz | -2.8 dBmV | 38.4 dB | 0 | 0 |
| 29 | Locked | QAM256 | 45 | 687000000 Hz | -2.6 dBmV | 38.4 dB | 0 | 0 |
| 30 | Locked | QAM256 | 46 | 693000000 Hz | -2.6 dBmV | 38.5 dB | 0 | 0 |
| 31 | Locked | QAM256 | 47 | 699000000 Hz | -2.5 dBmV | 38.5 dB | 0 | 0 |
| 32 | Not Locked | Unknown | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
Upstream Bonded Channels
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 1 | 5120 Ksym/sec | 17300000 Hz | 46.5 dBmV |
| 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 23700000 Hz | 46.5 dBmV |
| 3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 30300000 Hz | 46.5 dBmV |
| 4 | Locked | ATDMA | 4 | 5120 Ksym/sec | 36700000 Hz | 46.5 dBmV |
| 5 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | Unknown | 0 | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
Downstream OFDM Channels
| Channel | Lock Status | Modulation / Profile ID | Channel ID | Frequency | Power | SNR / MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Locked | 0 ,1 ,2 ,3 | 48 | 850000000 Hz | -3.4 dBmV | 37.5 dB | 1108 ~ 2987 | 60113364 | 13561874 | 5017 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV | 0.0 dB | 0 ~ 4095 | 0 | 0 | 0 |
Upstream OFDMA Channels
| 1 | Not Locked | 0 | 0 | 0 Hz | 0 dBmV |
Current System Time:Mon May 04 11:23:46 2020System Up Time:01:49:34
- tgaryAspirant
Not clear if the screen paste captured the uncorrectables on the OFDM downstream, but in a little under two hours up, it was 13561874 correctable, and 5017 uncorrectable.
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.- tgaryAspirant
FURRYe38 wrote:Have the ISP check the signal and line quality UP to the modem.
Be sure your using good quality RG6 coax cable up to the modem.Hi, and thank you. They did. The Xfinity tech checked the line from tap to modem, and said it was very strong. (There is a single splitter to pull off the TV line.) I figured my lines would be the first thing Xfinity would blame if they could.
