walruspete
Dec 13, 2018Guide
CM1150v Availability
Hi,
Does anybody know when the CM1150v cable modem will be available for sale? Thanks.
CPTWingit
Jan 29, 2019Guide
Sorry, very frustrating indeed. I gave up and bought a Motorola MB8600 as it was one of the 3 approved and compatible modems. Still no luck. At lease I can verify that I"m locked onto DOCSIS 3.1 as the lights are all blue. When running speed tests it will jump up to and over 1GBps but then bounce quickly down to under 500 and stay there. Doesn't seem to matter where it test, wired to modem, from wired router using Orbi's speed test, or wirelessly. All about the same. My money is that it's Comcast somehow. I will say also that I purchased an attenuator to tweak my signal strenght a bit. All of my numbers are well within optimal range now so no idea. The one Netgear guy who was helping abandoned ship on me as well, so there's that then. Good luck to you.
TedInCall
Jan 29, 2019Tutor
Unfortunately this is the ONLY gig-speed modem with Voice and comcast/xfinity does not offer or support seperate VoIP adapters and I have xfinity voice for my home phone line.
