karl_childers
Jun 20, 2023Aspirant
CM1150V Howto Do Port Forwarding
How do I configure port forwarding on my CM1150V cable modem? I must have done it before but I have forgotten how. The Nighthawk app doesn't seem to provide support for this modem. I have also tried...
- Jun 21, 2023
The router is a PC running Ubuntu 22.04. I forgot that I did the NAT there and allowed certain non-well-known ports through. I used to do it via the modem when I was using Comcast’s gateway. This is a much better solution because I have much finer control of my network.
karl_childers
Jun 21, 2023Aspirant
Jun 23, 2023Guru - Experienced User
CM series modems are and have only been modem only units. No built in router here.
C series modems are gateway modems with built in routers.
