DanMc85
Aug 27, 2019Tutor
CM1150V LACP LAGG Firmware Issue - Comcast V2.02.04 and V2.02.03
Anyone else notice issues with the Netgear CM1150V running on Comcast with the V2.02.x firmware? Particularlly with LACP/LAGG (IEEE 802.3ad) Ethernet Port Aggregation Enabled? I have noticed this...
DanMc85
Aug 27, 2019Tutor
Yes- everything is configured correctly in terms of LACP/LAGG and using both ports. As I mentioned, the Motorola modem didn't have this issue with same configuration. It most likely isn't on the firewall end of things.
Comcast discussion thread link, found another user with same issue with same modem and firmware:
https://forums.xfinity.com/t5/Your-Home-Network/Netgear-CM1150V-Extreme-Slow-Downs/td-p/3255727
Aug 27, 2019Guru - Experienced User
I believe NG is aware of this issue. Something to contact them about if you feel the need. No idea if or when it will be fixed.
