DanMc85
Aug 27, 2019Tutor
CM1150V LACP LAGG Firmware Issue - Comcast V2.02.04 and V2.02.03
Anyone else notice issues with the Netgear CM1150V running on Comcast with the V2.02.x firmware? Particularlly with LACP/LAGG (IEEE 802.3ad) Ethernet Port Aggregation Enabled? I have noticed this...
YoungSpicket
Sep 23, 2019Star
Thanks for the info. Can you post when the new Comcast firmware is available? I’ve had the modem unhooked in favor of my Motorola MB8600 since this happened.
Sep 23, 2019Guru - Experienced User
FW will be sent to your ISP then pushed from there. I would contact your ISP and ask them if they have any information from NG regarding this issue. Cable modem FW will only be sent to ISPs first so they can test and make sure it works on there network.
