DanMc85
Aug 27, 2019Tutor
CM1150V LACP LAGG Firmware Issue - Comcast V2.02.04 and V2.02.03
Anyone else notice issues with the Netgear CM1150V running on Comcast with the V2.02.x firmware? Particularlly with LACP/LAGG (IEEE 802.3ad) Ethernet Port Aggregation Enabled? I have noticed this...
couchgate
Nov 01, 2019Tutor
Does anyone know if the CM1200 has this issue as well? Paitently waiting a firmware update from Xfinity for the CM1150V....
cursixx
Nov 25, 2019Star
CM1200 and all LACP enabled Netgear modems have this problem. Just get a MB8600 or SB8200 because even with a fixed firmware on the Netgears it will take 6-12 months before providors push the firmware if they even do. I'm not sure how something like this passed Netgear QA for so many diffrent modem models.
- couchgateNov 25, 2019Tutor
Re: SB8200 - it has an issue with LACP where it will reset itself once about every 24 hours. I haven't yet tried the MB8600 for LACP.
- cursixxNov 25, 2019Star
I have the MB8600 and it has never had any issues with LACP out of the box. I also have a SB8200 and never ran into any interface or device resets with it using LACP. Netgear has three modems with this issue and all were released at diffrent times. I bought the CM1200 as soon as it was released but found it had the same firmware issues as the others. They even did customer beta units on DSLReports
- FURRYe38Nov 25, 2019Guru - Experienced User
I have not seen this with my CM1100. Thought I'm not on CC so I might not be effected.
NG is aware of the problem with the CM1200.
cursixx wrote:CM1200 and all LACP enabled Netgear modems have this problem. Just get a MB8600 or SB8200 because even with a fixed firmware on the Netgears it will take 6-12 months before providors push the firmware if they even do. I'm not sure how something like this passed Netgear QA for so many diffrent modem models.
I dont have the CM1100 or CM1150 but from my understanding they had the same issue with LACP. Have you used both with LACP enabled?
