DanMc85
Aug 27, 2019Tutor
CM1150V LACP LAGG Firmware Issue - Comcast V2.02.04 and V2.02.03
Anyone else notice issues with the Netgear CM1150V running on Comcast with the V2.02.x firmware? Particularlly with LACP/LAGG (IEEE 802.3ad) Ethernet Port Aggregation Enabled? I have noticed this...
ThePiston450
Nov 25, 2019Tutor
I Cooke with David from Comcast support in New Hampshire today. He escalated it to xfinity national who gets the new firmware. He was in contact with regional tier two support and the did read this article and the xfinity forum on page one of this forum. They will try and get the firmware update released. They did tell me to force a push simply unplug modem for 30 seconds and plug back in and it will check for new firmware. I will keep everyone posted if I make any progress but if more people call I would assume it would help to make them aware there are more people with the same issue.
Skeeterslint667
Nov 25, 2019Star
I would keep on them about this, they have already been sitting on the firmware with the fix for a couple months now.
- ThePiston450Dec 01, 2019Tutor
Just opened up support ticket with netgear.
Case #41993230
the cm1150 i purchased is advertised as multi-gig and the first feature listed is "
- Ideal for Gigabit cable Internet plan. Delivers true Multi-Gig Internet speeds with link aggregation** support.
https://www.netgear.com/home/products/networking/cable-modems-routers/CM1150V.aspx
Netgear please address this issue.
- ThePiston450Dec 02, 2019TutorLooks like netgear just closed my case less than 24 hours after opening it with no resolution, comments, or any communication at all.
- Skeeterslint667Dec 02, 2019Star
ThePiston450 wrote:
Looks like netgear just closed my case less than 24 hours after opening it with no resolution, comments, or any communication at all.They already know it has a firmware problem, they fixed it and sent the firmware to Comcast, it's now up to Comcast to push the firmware to our modem. Opening a ticket with Netgear isn't going to solve anything and will just tie up Netgear support for a problem that Comcast has to be the one to fix so they closed the ticket that they can't do anything about.
