DanMc85
Aug 27, 2019Tutor
CM1150V LACP LAGG Firmware Issue - Comcast V2.02.04 and V2.02.03
Anyone else notice issues with the Netgear CM1150V running on Comcast with the V2.02.x firmware? Particularlly with LACP/LAGG (IEEE 802.3ad) Ethernet Port Aggregation Enabled? I have noticed this...
AuxNuke
Feb 02, 2020Initiate
My quartely check in to see if anything has been updated here.
Really wishing I had gone with a different modem vendor :(
estradadad
Feb 02, 2020Star
You and me both, you and me both...crickets from both vendors and finger pointing. And really is an issue that they advertise it and don't deliver. 👨‍⚖️⚠️
- FURRYe38Feb 02, 2020Guru - Experienced User
"Dude just disable agg and run 1 cable. I’m pulling 986/42 consistent. No restarting, no slow down, no problem." :smileywink:
- estradadadFeb 02, 2020StarI am dude, but the point we are making is that it should work as intended, advertised and reason we bought it.
- FURRYe38Feb 03, 2020Guru - Experienced User
We get that. And thats something you'll have to wait for NG and ISPs to get working. For now, use it with LAG disable or find something else that doe work for your needs. Any one tried the CM1100?
- estradadadFeb 03, 2020StarThanks. We get that too and already doing that.
Good luck.
- YoungSpicketFeb 08, 2020StarIt’s been like that for almost a year. Take it back and get a Motorola.
- estradadadFeb 12, 2020StarYes, thanks. It's the only choice at this stage since it's evident that it won't be resolved anytime soon or at least have a definitive response or timeline from the responsible party.
