DanMc85
Aug 27, 2019Tutor
CM1150V LACP LAGG Firmware Issue - Comcast V2.02.04 and V2.02.03
Anyone else notice issues with the Netgear CM1150V running on Comcast with the V2.02.x firmware? Particularlly with LACP/LAGG (IEEE 802.3ad) Ethernet Port Aggregation Enabled? I have noticed this...
KatTheFoxtaur
Sep 09, 2020Aspirant
I'm having the same issue here, still v2.02.04 of course. Ended up disabling LACP on both sides, we'll see how that goes.
I had contacted Netgear for a warranty replacement, since I was having the issue since the beginning, and have tested/swapped literally everything between the tap block (on the pole - Comcast tech even ran a new drop from the tap) and the computers (wiring, new runs, etc.) I came to the conclusion that it's either an issue with the modem itself, or something upstream from the tap block on Comcast's infrastructure. When I got the replacement modem, I remember pretty specifically not enabling LACP on the replacement, but still had the slowdown - it did take a few days before the first time it occurred, but now it's back to <24 hours.
For those suggesting other modem models, please remember that some of us actually do need the voice ports. I actually have two active landlines (one for me, one for my mother-in-law), so a non-voice modem isn't an option.
Hypaspazz
Sep 24, 2020Tutor
So I was also having issues with the V2.02.04 firmware that Comcast pushed to my modem when I first installed it. I was running through an RAX80 at the time and every 4-6 hours DL would drop to 40Mbps and UL would stay at 40 Mbps. I had the techs here and they said all is good with the signal strength and modem behavior as far as they could tell.
I was waiting for a firmware patch like everyone else. I ended up swapping the router out to the RAX120 since it has more wireless streams for my multi-tasking gamer kids and a Multigig port to connect to my SX10 switch. I am almost certain it is coincidental but ever since I put the new router into the network setup I have been just under DL 1200 Mbps without needing to power cycle the modem every 4-6 hours. When I check the modem it now says firmware V4.02.02. Has anyone else seen this version firmware pushed to their modem by Comcast?
Just for reference my RAX120 router firmware is V1.0.0.78.
- KatTheFoxtaurSep 24, 2020Aspirant
HypaspazzLooks like I'm still on v2.02.04 myself. I did disable LACP (on both sides of course - the modem and my router [a Dell PowerEdge server running Netgate pfsense]), and that resolved it for me - I have not had reduced bandwidth ever since, and it's been at least a couple weeks since I last rebooted the modem.
- FURRYe38Sep 24, 2020Guru - Experienced User
to be sure that modems get a change to update FW from the ISP, power OFF the modem for 1 minute then back ON. Some ISPs will auto push FW to modems during this power cycle. If not, contact the ISP and ask them to update.
- KatTheFoxtaurSep 25, 2020Aspirant
FURRYe38 Indeed, I know I'll need to reboot and have not done so yet; however, if Comcast has finally updated the current firmware on their side, I'll give it a shot soon!
Also, total off-topic but wondering because I keep seeing your username over here...are you a furry? :3
