Scott_UU's avatar
Apr 13, 2019
CM1150V LED says Partial Service, but all channels locked
I initially had some "partial service" issues, where only (2) of (4) upstream channels were locking.  The GUI said "partial service" above the channel lists, and the upstream light was flashing -- and I really did have "partial service" at that point.  But a Comcast tech came to the house, removed a noise block at the pole, and now all channels are locked.
So now, with all provisioned channels are LOCKED, the GUI no longer says "partial service".  But the CM1150V's upstream LED is still flashing.
Why would the upstream LED flash, when all provisioned channels are locked?  I'll paste the channel status below, all provisioned channels are LOCKED but the US LED is still flashing, flashing, flashing.  WHY???
Startup Procedure  Procedure Status Comment
Acquire Downstream Channel 663000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Security Enabled BPI+
IP Provisioning Mode Honor MDD honorMdd(4)
Downstream Bonded Channels
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM256 29 663000000 Hz -0.3 dBmV 38.8 dB 0 0
2 Locked QAM256 1 483000000 Hz 0.1 dBmV 39.5 dB 1 0
3 Locked QAM256 2 489000000 Hz 0.1 dBmV 39.5 dB 0 0
4 Locked QAM256 3 495000000 Hz 0.1 dBmV 39.5 dB 0 0
5 Locked QAM256 4 507000000 Hz 0 dBmV 39.5 dB 0 0
6 Locked QAM256 5 513000000 Hz -0.3 dBmV 39.6 dB 0 0
7 Locked QAM256 6 519000000 Hz -0.1 dBmV 39.6 dB 0 0
8 Locked QAM256 7 525000000 Hz -0.1 dBmV 39.6 dB 0 0
9 Locked QAM256 8 531000000 Hz -0.2 dBmV 39.6 dB 0 0
10 Locked QAM256 9 543000000 Hz -0.2 dBmV 39.5 dB 0 0
11 Locked QAM256 10 549000000 Hz -0.1 dBmV 39.4 dB 0 0
12 Locked QAM256 11 555000000 Hz -0.1 dBmV 39.3 dB 0 0
13 Locked QAM256 12 561000000 Hz 0.1 dBmV 39.5 dB 0 0
14 Locked QAM256 13 567000000 Hz 0.1 dBmV 39.5 dB 0 0
15 Locked QAM256 14 573000000 Hz 0 dBmV 39.4 dB 0 0
16 Locked QAM256 15 579000000 Hz 0 dBmV 39.4 dB 0 0
17 Locked QAM256 16 585000000 Hz -0.1 dBmV 39.3 dB 0 0
18 Locked QAM256 17 591000000 Hz 0 dBmV 39.4 dB 0 0
19 Locked QAM256 18 597000000 Hz -0.1 dBmV 39.3 dB 0 0
20 Locked QAM256 19 603000000 Hz -0.2 dBmV 39.2 dB 0 0
21 Locked QAM256 20 609000000 Hz -0.4 dBmV 39.1 dB 0 0
22 Locked QAM256 21 615000000 Hz -0.5 dBmV 39.1 dB 0 0
23 Locked QAM256 22 621000000 Hz -0.4 dBmV 39 dB 0 0
24 Locked QAM256 23 627000000 Hz -0.4 dBmV 38.9 dB 0 0
25 Locked QAM256 24 633000000 Hz -0.3 dBmV 38.9 dB 0 0
26 Locked QAM256 25 639000000 Hz -0.5 dBmV 38.9 dB 0 0
27 Locked QAM256 26 645000000 Hz -0.6 dBmV 38.8 dB 0 0
28 Locked QAM256 27 651000000 Hz -0.5 dBmV 38.7 dB 0 0
29 Locked QAM256 28 657000000 Hz -0.4 dBmV 38.8 dB 0 0
30 Locked QAM256 30 669000000 Hz -0.4 dBmV 38.7 dB 0 0
31 Locked QAM256 31 675000000 Hz -0.5 dBmV 38.3 dB 0 0
32 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Locked ATDMA 5 5120 Ksym/sec 30100000 Hz 38.8 dBmV
2 Locked ATDMA 6 5120 Ksym/sec 36500000 Hz 39.8 dBmV
3 Locked ATDMA 7 5120 Ksym/sec 17300000 Hz 36.8 dBmV
4 Locked ATDMA 8 5120 Ksym/sec 23700000 Hz 37.8 dBmV
5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
Downstream OFDM Channels
Channel Lock  Status Modulation / Profile ID Channel  ID Frequency Power SNR / MER Active Subcarrier  Number Range Unerrored
Codewords Correctable  Codewords Uncorrectable  Codewords
1 Locked 0 159 722000000 Hz -0.1 dBmV 38.2 dB 1126 ~ 2969 10674825929 13797 0
2 Not Locked 0 0 0 Hz 0 dBmV 0.0 dB 0 ~ 4095 0 0 0
Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0 dBmV
Current System Time:Sat Apr 13 16:19:15 2019
System Up Time:3 days 04:33:54
  • FURRYe38's avatar
    I recommend you guys contact your ISP. They have control over how this modem gets associated with there sysetm. Have them look in to there logs.
    Has a reset been performed on the modem yet?
    • Scott_UU's avatar
      Scott_UU
      Star
      I have been in contact with Comcast, and verified that ALL PROVISIONED CHANNELS ARE LOCKED -- upstream and downstream.  And yes, the modem has been power cycled, and even factory reset multiple times.  Always same result.
      All provisioned channels are locked, and the modem's GUI does *not* indicate partial service -- nor are there any partial service errors in the logs.  But the upstream LED is still flashing.
      Looks like a firmware bug to me.  Odd that Netgear won't answer.
      • FURRYe38's avatar
        It's probably a HW problem. I would try another CM1150v.
        Others have not methioned this and FW comes from ISPs after NG give it to the ISP to test out on there system.
