RossS's avatar
RossS
CM1150v notice 6 message
I keep getting this  notice:
CM-STATUS message sent. Event Type Code: 16; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=28:80:88:d4:29:28;CMTS-MAC=00:01:5c:ad:ea:57;CM-QOS=1.1;CM-VER=3.1;
Always the same message just would like to know what it means. Thanks
  • Maintance person for xfinity came and checked outside feed to my neighbor hood (my part) and found problem. Now all dBmV values are in spec. Thank you for the help.
  • plemans's avatar
    Log into the modem and get a screen shot of the cable connections page and the complete lots. Not just 1. they're used together.
    • RossS's avatar
      RossS
      • RossS's avatar
        RossS
