Jack1969
Jan 19, 2019Tutor
CM1150V Telephony modem
I just purchased a CM1150V Telephony modem. The Quick start gives a link to find out how to use LAN ports 2,3,4, but I cannot find the answer at this link. My port 1 works fine connected to my rout...
antinode
Jan 19, 2019Guru
> [...] Anyone know how to use the other LAN ports?
Someone might, but if Netgear published anything, then they hid it
very well.
Visit http://netgear.com/support , put in your model number, and
look for Documentation. Get the User Manual. Read. I see:
Ethernet ports 1-4. For installation and activation, connect a
computer to Ethernet port 1. After you install your cable modem
and activate your Internet service, you can disconnect your
computer and connect a router to Ethernet port 1. Your cable modem
comes with plugs that cover Ethernet ports 2, 3 and 4. For more
information about Ethernet ports 2, 3, and 4, visit
netgear.com/support/product/CM1150V.
[http://www.netgear.com/support/product/CM1150V]
I'd've thought that "plugs that cover Ethernet ports 2, 3 and 4"
would be a hint. I'd also guess that you'd need a NAT router if you
wanted to connect multiple devices to any ISP connection which provides
a single public IP address.
> [...] I cannot find the answer at this link. [...]
Same here. Typical Netgear documentation.
