Jack1969
Jan 19, 2019Tutor
CM1150V Telephony modem
I just purchased a CM1150V Telephony modem. The Quick start gives a link to find out how to use LAN ports 2,3,4, but I cannot find the answer at this link. My port 1 works fine connected to my rout...
Dantepace
Apr 28, 2019Aspirant
If I have one lan PC and 2 wlan roku....my 2nd lan PC won't go into the web or do a speed check.
Very disappointed with the product...about to return it.
- FURRYe38Apr 29, 2019Guru - Experienced User
The modem needs a external wired router put behind it. Then you can connect all the rest of the devices to the router. ALL CM series modems are modems only. C series modems are modems with built in router and wifi features for future reference.
