ninjaroo's avatar
ninjaroo
cm1150v Voice modem Mta provisioning rejection Xfinity
I had new Xfinity Gig service with Phone installed last sunday. At that time my phone was working being directly connected to the modem tel 1 connection. Fast forward to tuesday the phone was unplugged from the outlet  and the Modem was accidently unplugged at the outlet later in the day. After plugging the Cm1150v back in i noticed the tel 1 was not lighting up. I logged into the modem and saw mta provisioning rejected.
I worked with comcast to get a modem profile resent and rebooted the router twice and we couldnt get the phone line working. Now a tech is coming. Is there anything I can do with the modem or is this a comcast issue.
Hardware Version 1.01
Firmware Version V2.02.03
Cable Modem Serial Number
CM Certificate Installed
MTA Provision Status   Rejected
MTA MAC Address   78:
MTA Telephony Line1 Status   Disabled
MTA Telephony Line2 Status   Disabled
MTA Line1 HD Audio Status   Enabled
MTA Line2 HD Audio Status   Enabled
2019-03-19 21:02:22 Provisioning Complete - Warnings
m78D294596429.chlm8.ma.comcast.net/21.33.48.151
Time Priority Description
Tue Mar 19 21:01:39 2019 Warning (5) Dynamic Range Window violation
Tue Mar 19 21:01:39 2019 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=28;CMTS-MAC=94:d4:69:22;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 19 21:01:39 2019 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=;CMTS-MAC=94:224:69:;CM-QOS=1.1;CM-VER=3.1;
Tue Mar 19 21:01:28 2019 Notice (6) TLV-11 - unrecognized OID;CM-MAC=78:d28;CMTS-MAC=9:22;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=7828;CMTS-MAC=9:22;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Warning (5) Lost MDD Timeout;CM-MAC=78:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=78:d2:94:59:64:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=78:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    ask them to remove it completely and reprovision this.
    this looks like MTA config file issue.
    • ninjaroo's avatar
      ninjaroo
      I beleive they did that because I was asked to hard reset the modem and waiting several minutes for it to return.
