Julia37
Mar 19, 2021Aspirant
CM1200 and Xfinity connection issues
I have new Modem for about a month. I registered modem with Xfinity successfully. I use a Google Wifi Router.
I inconsistently have connection issues. DownStream is tyically blinking.
Firmware is V3.02.01
attached is my event log - upstream shows Unlocked.
I've had a Xfinity tech come out and said it was a port issue on outside of home. Worked ok for about 5 days. Today it is crashing every 10-15 mintues. Xfinity tech is coming out again this weekend
Please give any guidance.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853- Julia37Aspirant
Were all the Downstream channels locked in? I see 31 is locked in.
What speed do you pay for UP and DOWN?
Your only getting 1 channel on the UP BONDED locked in, there should be 4 I believe
Is LAG enabled on the modem? Link Aggregation
The ISP should look into this with you. Have them review the signal up to the modem and the event and cable connection logs.
